Transfering Garmin Favorites to Command Navigation
Ford C max , C300 4-matic
Is there a simple way to transfer all my Favorites from Garmin Nuvi to the MB Navigation system ? Tks
In a simple way - no ...
It's possible from COMAND to save POI's from COMAND to the SD card - and COMAND provides a way to convert a POI to a stored address ....
I don't have a experienced answer if your NUVI can store to a SD - or if COMAND would "read" Nuvi written SD .. interesting question.
Kindof interesting question...
I've not done this particular exercise myself and so I don't know if the data and format of your Garmin .gpx will be OK. For my last holiday, I used Excel to create the data manually, then imported it to Google MyMaps (not ordinary Google Maps) and used that output to make a .gpx file for my SD card, so I can confirm that the car is capable of accepting homemade user data, even if the way to get there is tedious! There are one or two utilities on the web to help with file conversion, so if the Garmin .gpx isn't all fine, you ought to be able to clean it up with one of those.
Good luck!
