Keyless-go
I am thinking of purchasing a GLC and was just wondering if Keyless-Go is a must have feature or not? If I don't get it, do I still get the push button start to turn on / off the car, or will I always have to keep the key in the ignition?
I have a BMW and am used to the Comfort Access option that allows you to unlock the door without pressing the button on the remote. But without it, you can still start the car without having the key in the ignition. Most of the time I just use the remote to unlock anyways.
We must be spoilt, we will not buy a car unless it has this feature, and a few more on our ever increasing"List" !
Last 5 have had it, one of those things, once you have it, you never go back.
Yes electrics could be a problem, but so too have been mechanical tumblers in barrels.
Also the Grand Cherokee has the keyless go standard, whereas its an option on the Mercedes -
There have been areas in the US where this has been taken advantage of.
Not just an MB problem, others suffer, some are worse.
People with Keyless go are advised to keep the keys well away from the door at home, preferably in a metal box designed to block the signal.
https://www.thelocal.de/20160317/key...car-club-shows
I do recall reading an article about peoples prius being broken into because there was tool that amplified keys signal so if you had key on kitchen counter and it was close enough to your drive way the thief would be able to open the door.
(it's this way in the US)
