Tyre scrubbing on (full) lock
#627
Hi Phil. I’ve done just over 16,000 but the original fronts were changed at roughly 4,000, so 12,000ish on these fronts. The original rears are still going strong as MB flatly refused to change them at the same time as the original fronts were changed.
Tyres are are covered under my lease but I understand they were in the region of £325 each. That’s from Kwik Fit, which is the Lex approved tyre supplier. Hope you get a satisfactory conclusion with yours soon.
#628
Thanks Andy, that's not a bad mileage but cost of the tyres is not good. Not holding my breath for resolution and waiting decision from motoring ombudsman. MB should be ashamed, they admitted the issue and came up with a solution, they then found out the solution wasn't available for 19 and 20 inch tyres and have not come up with an acceptable solution..
#629
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
Some tyre info for digest.
On GLC 250 in Dubai – 20" rims – Dunlop Sport Maxx MO and Pirelli Scorpion Verde run flats.
GLE 43 in Dubai, Pirelli P Zero, MO, 275/45/R21. 107Y
GLC 250 in Melb – 19" rims – Hankook Ventus S1 EVO2, SUV, MO (treadwear 220, traction AA, temp A)
GLC 250 in Townsville – 20" rims – Goodyear Efficiency Grip, run flat 101Y
GLC 250 in Hawaii – 20" rims – Goodyear All Season M&S, MO. run flats – yes it is tropical and only snows on volcano sometimes, never on surrounding isl, but can get very wet.
My GLC delivered with 20" Pirelli Scorpion Verede run flat, 101W
Replaced with Goodyear All Season M&S MO, runflats, 105Y (Treadwear 560, traction A, temp A ) Made in Germany.
MB UK have replaced 20" rim tyres with Vredestein 5 series ( not imported into Oz as yet) version which also seem to work re Juddering.
MB AU have used Continental conti-seal 21" with "star" * on sidewall, denoting designed for BMW and Rolls Royce – working very well on GLC 43 owners on front rims, not sure what happened with rear rims as they are staggered in size and not all tyre manuf have the rear tyre size in their design.
#630
Trial shipment of Goodyear Eagle Sport, RFT, ALL Season, M&S, 255/45R20 fitted to GLC last Sept. 90% improvement immediately coming out of winter into Spring. Summer has been good, about to head into Autumn, real test will be Aussie winter and cold wet mornings with U Turns and right turns around roundabouts.
All Season tyres very difficult to source and my guess is those designs that are working will see extreme shortage with Tyre manuf being unable to supply demand. Volume numbers in MB unique sizing will not assist.
Found same Goodyear’s fitted to GLC43 in Hawaii, new on dealer floor....... Hawaii does not get as cold as Oz or UK, but an be very wet, so I guess our US cousins are getting an allocation when built in Germany.
I have done around 8,000km I think and tread wear down from 7mm to 5mm approx; wear bars kick in at 1.5mm. Rotating around 8,000km.
Tread wear rating is 560 I think, Pirelli Scoprion Verde, summer tyres was 400 tread wear; I got around 42000km from them, allowing for tread depth when I had Goodyear’s fitted. Hopefully the Goodyear’s will last more. In USA these have a 50,000 mile g’tee, we do not have such warranty here in Oz.
Hope this helps – All Season tyres seem to be the reasonable workaround. We do not have the Vredestein tyres our UK cousins have to evaluate, they too seem to be getting good reviews.
I may be able to help have some of these (Vredestein) imported as a pallet load, but need to do far greater research before committing and going into partnership with one or two other GLC owners and the Agent
#631
I bought a 2017 GLC43 off the showroom floor last year in Houston, US. At the time using the online builder you could spec all-season or summer tyres (and stock models reflected this), at some point since it has changed so you have no choice other than all-season. They also changed the default tyres from 245/285 to 225/285 from 2017 to 2018 models. I think those changes are very telling.
We got the same Good Year Eagle Sport tyres as you mentioned. Decent tyres, but have already had a nail in 1 front and a screw in the other after 7k miles so getting to 50k miles looks unlikely. Thanks Texas
![wwf](https://mbworld.org/forums/images/smilies/chairshot.gif)
Teckno (02-20-2018)
#632
Hi All,
Was in Mercedes in Adelaide at the weekend and noticed a brand new GLC 43, 21 " rims waiting for the new owner to collect that morning . The dealer had already swapped out the Continental MO rated front tires to the Continental conti-seal 21" with "star" *rated prior to delivery.
Back tires unchanged Continental MO marked.
Teckno (02-21-2018)
#633
On another matter, some good news to report.
Dealer logged another report to MB HQ on Coupe tires, staggered rims, 255 and 285 on 20” AMG rims.
Original Michelin Latitude 3 summer, non run flats have been replaced after 14000km, wear rates were acceptable, though I did not measure them before leaving car, I should have to gain a better idea of wear rate – not permitted to keep casings as MB may claim against Michelin ?
Now fitted same tyres as I have been running since last year, the Goodyear Eagle Sport, All Season, RFT, M&S tyres. Now fitted to front and rear.
This should be a solution for other Coupe and GLC 43 owners with staggered 20” rims.
Goodyear’s are scarce, I think MB have imported their own stock pile to meet client demand.
Ride seems ok so far, PSI set at 36, though another Service Tech suggested 40psi ? As new default setting to assist with crabbing. MB also still fine tuning align settings and toe-in I think.
Hope to get new data from alignment machine to see trending figures and default settings.
Hope this helps fellow owners with winter approaching.
#634
Update on Tyre wear. Goodyear Eagle Sport, All weather, M&S, MOE, 255 series on 20” AMG rims.
These replaced my Pirelli Scorpion Verde, Summer tyres, MOE, LASTED approx 35000km, may have got 42,000km before wear bars kicked in.
So measured tyres earlier myself as Dealer did not record Tyre wear on recent service.
Use small Michelin Tyre pressure unit with Tyre depth reader, sells around $25 from AutObarn stores.
Tyres when new – 8.0 to 7.9mm
Four Tyre channels to read, tyres have an outer side for fitting, inside channel seems to be 7.7 deep. Outside leading edge depth around 6.7mm.
My tyres on GLC, Fitted Sept 17.
Travelled approx 8000km
Wear is approx.
Tyres just rotated front to rear, so readings are rears in reality for fronts now, etc.
Front driver – edge 6.2, across 4 channels, 7.4 and 7.3mm
Front pass – edge 6.3, across, 7.3 and 7.2mm
Rear Drv side – edge 5.9, across, 7.1 and 7.2mm
Rear pass – edge 6.1, across, 7.0 and 7.1mm
When New tyres are :
Edge 6.7mm and across between 8.0mm and 7.9mm
So allowing for start 8.00 mm and average now after 8000km, with depth say 7.2mm and allowing end safe depth of 1.5mm, we have 6.5mm to effectively use.
I have used 0.8mm for 8000km.
To keep it simple, not allowing for any Tyre mixture wear pattern in manuf layering and running at 36psi, let’s say 1.0mm for 8000km. Therfore I think I could possibly achieve 52000km, if rotated @ 10,000km and aligned on rotation.
So I expect a range of 50,000 to 60,000km from these All Season, Run Flat, MOE tyres.
Most of my driving recently has been 35km in morning and 35km in afternoon, city and freeway driving ranging from 40 to 80kph. Couple of country runs of 250km each way, day and night driving in Spring and Summer conditions, couple in heavy rain, majority of driving on dry roads, not a lot of rain this year.
So Treadwear rating of 560 for Goodyear’s seems reasonable (Pirelli treadwear rating is 400).
Hope this helps re considering, All Season, RFT, MOE tyres as an alternative
Wear is approx.
#635
Pr
Yes and the sales director can recreate it on his own GLC 250d AMG Sport demonstrator. Actually he can do it on both he had since September.
To hope they can resolve it, I find it fascinating how the left hand drive models don't seem to have this and are very quiet about it. What about those RHD models from SA and Oz that are on here? Have you guys got anything like this? Guess the temperatures don't get cold enough![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#636
right to be forgotten
Hey @phil I thought there was a fix in this thread but I can’t see anything.
Mine is still bad as ever, and not only on the tyre front falling appear also now has the air suspension, parking sensors, air bag and steering column faults.
Trying to figure out what we will go for as i have enough, especially with the lack of customer service from Mercedes. A shame as at one point I was thinking of going back for another GLS. But yet again they are up to their old tricks of blaming my driving. Idiots.
#637
Sad to hear JP, thought it had been sorted. I ended up going to the ombudsman as they only offered me a set of winter tyres which would mean changing twice a year and possible wheel damage. Eventually they have given me a set of AMG multi spoke 20 inch wheels with winter tyres. It was too late to put them on this year so they are stored at the dealers ready to fit next winter. At the moment I would probably have another GLC as there isn't anything out there that I prefer.
Let us know what you go for when the time arrives.
dejongj (05-15-2018)
#638
That is exactly our problem, otherwise we would have gotten rid much sooner. There isn't anything else out there that I really truly like. It is rather annoying actually
#firstworldproblems
#639
Cooler / wet weather in Perth has really made the crabbing more pronounced. So i thought i'd check my tyre pressures again, and found them all around 34psi.. I brought them back up to 37psi where i usually have them. This has made a huge difference to the crabbing, to the point where it is almost not noticeable. Im surprised such a subtle difference in tyre pressure could make such a big difference. All my tyres have worn more on the outside than the inside or middle of the tyre, which suggests to me that the recommended factory tyre pressure of 32psi is way off.. I may experiment a bit more with higher pressures ( higher than 37psi ) to see if the crabbing goes away completely, and hopefully even out the tyre wear.
#640
What tyres are you running? I found the opposite on my Bridgestones, lowering the pressure to 34 helped a bit with the crabbing.
Beware of over inflating as I was able to wear the rears slightly quicker than the fronts doing this. My tyres were never rotated and lasted 36000 kms.
I have switched to non RFT and have no crabbing, even in the wet and cold here in Sydney at the moment, even in car parks. Running 36 psi seems the sweet spot. With non RFT I have much better comfort and vastly improved handling and quietness over the MOE tyres which I thought were actually pretty quiet already.
I suspect some crabbing will creep back when the tyres are worn but time will tell...
cheers.
#641
Hi Tigerx,
cheers.
cheers.
Thanks for the tip Redrover!
#642
Ive got the staggered setup on the 43. Conti non run flats 255's on the front 275's on the back. I might have to try Bridgestones next. I dont think i'll get a lot of miles out of the front tyres. at just over 8000km's on the clock i reckon they are half worn, especially the outside of the tyre.. I wont be buying Continentals again, that's for sure.
Thanks for the tip Redrover!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I have a friend in Melbourne with a GLC43 and he had his tyres replaced (due to crabbing) when he threatened to return the car shortly after buying it. I will need to check what they replaced them with but from memory it was another type of continental Run Flat.
Continentals have a bad reputation for wear but what you are experiencing seems excessive.
#643
Ive seen a few people in the US have used Atturo tyres as a substitute. They seem to get pretty good reviews. Looks like they are available in Australia, and pretty cheap too!
#644
Personally I would go for the Kankooks over these (which I did). Mercedes are actually doing a MO tyre vision of the Hankooks for the smaller size GLC rims. SUV tyre though, not the k120's I put on.
tiger_x (07-04-2018)
#645
New Tyre in the mix.
From UK MB forum, FYI...
Judder and tyre change
When my 2016 GLC 250d went in for the steering recall, I was asked about the juddering they noticed when they had the steering on full lock on wet ground after they had washed it. I had assumed it was a foible of the car.
I was told it WAS a fault and there is a fix for it. I was also told that I had to make a complaint to have the fix, and that my car was able to have the fix at no charge. The criteria were, the car had to be under 2 years old, and under 19,000 miles.
The fix was to replace the original tyres with Michellin Crossclimate SUV tyres (total value £1100).
I complained and the tyres were replaced.
The treads are very different - different enough for the guy at the gas station to comment on them.
Interesting info, unsure of rim size in this example.
#646
Update on Continentals 21' MO front tires change by Mercedes to Continentals 21' Star rated. Done about 10,000KM on them now, wear seems to be above average, expect to get maybe another 10,000km out of them (well I'm hoping) .
When newly fitted they almost cured the crabbing issue in cold weather.(never been a problem in warm weather even on the MO Tire).
But as dejongi experience, as they wear crabbing does seem to come back. It is winter here in Adelaide and it has been cold (well for Australia) and I have noticed the crabbing return, but still no where near as bad as the MO marked tires in similar conditions.
As the tires wear even more it may get worst....
I'll update in another 5000km.
Star rated tires still seem to be the best solutions at the moment for 21' rims.
Has anybody taken delivery of a GLC 63s yet, just wondering if the issue is present???
Might just pop in to Mercedes and have a little test drive of one and see for myself before the weather starts to warm up.
#648
“ Some interesting comments re test of GLC 63.
Ride comfort is decent for a performance SUV, but even in Comfort mode you will feel every bump, crack and expansion joint in the road. That's likely due in part to this tester's optional 21-inch wheels, which look fantastic but wear tires with relatively skinny sidewalls.
In tight, low-speed turns (think getting out of a narrow parking space) you'll also feel some hopping as that rear differential binds a bit; it's a habit familiar in quite a lot of high-performance vehicles.”
So we now see a reviewer suggesting it is a ‘characteristic’ - how quaint and convenient.......
https://www.cnet.com/roadshow/review...38403791806709
Link to full article.
#649
Comment lodged on our cousins GLC site in UK...
Initially AMG customer services offered me a set of winter tyres, I refused these at it would have meant that the tyres would have to be changed 6 times during my ownership and I feared the wheels would be damaged. They refused to budge on this and I went to the ombudsman.
This is the letter I received from the ombudsman albeit after 5 months, if you need any further info let me know.
I will have a set of 20 inch AMG wheels with winter tyres for sale in March 2020 as I can't see me getting another GLC unless they solve the issue, shame in that it is a great car apart from this.
Our process of Early resolution
In regards to your complaint, we refer your contentions over to the business with the evidence you intend to rely on.
The business will then be given an opportunity to respond to that case file upon which we will offer our opinion as to whether we consider this to be a reasonable outcome or if the matter requires formal adjudication.
The business' response
Initially I would like to highlight some information to better explain the customer’s concerns.
As indicated in the internal letter sent to Retailers, the tyre skipping concern has been investigated by our technical specialists as well as independent experts such as DEKRA who concur that the cars remain completely safe to drive. The concern is more pronounced in cold weather and when larger wheels and low profile tyres are fitted. This is due to the flexibility of the tyre sidewall.
Mercedes-Benz Cars UK have looked to assist customers wherever possible to alleviate this comfort issue as a gesture of goodwill. In order to do this, tyres must be sourced that not only have the required flexibility in cold weather but also meet with Daimler AG approval.
Depending on the wheel and tyre size combination this is not always possible. Tyre characteristics and availability are something that are outside of our control. The All Season tyres mentioned in the internal letter sent in February were subsequently deemed to be unsuitable for the Mercedes-AMG GLC 43 and so alternative options must be considered.
The customer has been offered 19” winter tyres or a 50% contribution towards 21” wheels with summer tyres. I understand the customer has declined both of these options.
We are now able to offer the customer a further option of having 20” wheels with winter tyres installed. This will mean the tyres do not need to be removed from the wheels when changing from summer to winter tyres and so alleviating the customer concern of possible wheel damage.
Whilst I would be happy to make arrangements with Mercedes-Benz of Poole for these wheels and tyres to be installed at no cost to the customer, we would not look to cover additional charges incurred during future swapping of these wheels or the storage of the removed wheels.
Outcome of Early resolution
In review of the submissions of both parties, I would note it is asked of me to consider whether there is reason to escalate the matter to adjudication, or if the outcome offered is to my mind reasonable.
I must note that the manufacturer is only liable under our code of practice for certain provisions that concern their advertising information, their customer care, the warranty provisions etc.
As such I need to consider whether this is a rejection issue, for which the consumer should be contacting his retailer, or as the business asserts a comfort issue which can be alleviated by provision of changing the wheels.
I can see that if these wheels are fitted to the vehicle, this may alleviate the issue which would therefore not be a defect of the vehicle as prescribed by the law, and so would be suitably remedied by the offer made.
As such I would support this as a way to remedy the issue at current, and suitably meet their liability under the new car code.
Next steps
Having considered your complaint, I don't think I have enough evidence to uphold it in full. However, the accredited business has offered to change the wheels to a suitable remedy as a gesture of goodwill.
After considering all of the evidence, I think this is a fair way to resolve your complaint and would therefore encourage you to accept this
If you disagree with the gesture offered, please let me know your reasons why - within 10 working days - and I will see if it changes my mind.
Kind regards,
Charles Woodgate AffIMI
Adjudicator
The Motor Ombudsman Limited
Next steps
Kind regards,
Adjudicator
#650
So as a new GLC43 owner and new to the forums, firstly "hi"!
I just bought a GLC43 as a demo with 6500kms on it. I have now done 7500kms and the front continental 21" tryes are at wear indicators.
I live in Adelaide, AUstralia. I have been skimming this thread but essentially i know MB take no responsiblity for this.
What is the general course of action here to ensure longer tyre life:
1. Not get Continetnal tyres.
2. Get alignments done regularly
3. rotate tyres regulary
Cheers,
Ili
Cheers,
Ili
