GLC spare tire options
Old Jun 29, 2017 | 10:04 PM
  #76
bips's Avatar
GLC 250D
Originally Posted by mikbar2
As I stated in an earlier post no amount of glue or even dyna plugs will fix a cut.
As I stated in an earlier post, even RFT will leave you stranded, if more than 80kms from a tyre shop or MB dealer. At least a plug kit gives you a chance, *if* the hole is pluggable. The only guaranteed solution is a full-sized spare. I know not everyone wants to / can carry one. You pays your money ....
Old Jun 29, 2017 | 10:14 PM
  #77
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
I would love a full size spare. There is no room for it. I remember the good old days when I owned BMWs with a spare on an alloy wheel.
Old Jun 29, 2017 | 10:15 PM
  #78
ajmtbm's Avatar
Mercedes-Ben GLC300 4Matic
a donut would be fine with me...
Old Jun 30, 2017 | 11:49 AM
  #79
mikbar2's Avatar
2015 C300, 2015 F-350 Platinum, 1969 Mach 1 428cj, 2007 Roadking
^^ Double Ditto for me.
Old Jun 30, 2017 | 12:41 PM
  #80
dieseldoc's Avatar
I think we all have the same sentiment.
Old Jul 17, 2017 | 06:20 PM
  #81
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
Originally Posted by SerenityNow
Interesting to note the speed limit and drive distance on the pictured tire is identical to a zero pressure extended mobility tire.
Old Jul 17, 2017 | 06:53 PM
  #82
ajmtbm's Avatar
thats a good catch
do all temporary spares have a mileage limit on them?
Old Jul 17, 2017 | 07:03 PM
  #83
dieseldoc's Avatar
My understanding is most do have a limit of speed and distance.
Old Jul 17, 2017 | 07:31 PM
  #84
bips's Avatar
GLC 250D
And that's precisely why I wasn't going to buy one when I had RFT. Plus the price was significantly more than a complete fifth wheel. That said, there is still an advantage to the emergency in those instances where the tyre damage is such that even a RFT tyre can't be driven on, which has happened to both me and a family member (X4) recently.
I understand the speed and distance limits on a deflated RFT. I understand the speed limits on an emergency spare, as the handling will be quite different. But I don't understand the distance limits. If you crunch the numbers, the diameter of the emergency is close enough to the original, so what's the reason for the distance limit?
To respond to the question "do all temporary spares have a mileage limit on them?", Subaru are an exception. The Outback and similar have space-saver spares that are not so limited. That maybe because their tyres are not so wide as the 235 / 255 that we have. On the other hand, a friend has a Mazda 3 and that has a speed and distance limited spare, which strikes me as odd. In this country it's not hard to be more than 80kms from help, and if you were you may not have phone coverage.
Old Jul 27, 2017 | 06:24 PM
  #85
Eric_John's Avatar
2011 C300
Grabbed this 2003 ML spare/lugs/wrench (couldn't find the jack) for $20 I'll test fit in a few days and update.
Old Sep 13, 2017 | 04:13 PM
  #86
Eric_John's Avatar
2011 C300
Update: Had new non run flat tires put on and the ride is so much better. Also, I had the technician test fit the above spare on front to see if it cleared the calipers and it fits no problem.
E
Old Sep 13, 2017 | 04:39 PM
  #87
mikbar2's Avatar
E
And the spare fits where? We use our cargo space.
Old Sep 13, 2017 | 05:07 PM
  #88
Eric_John's Avatar
2011 C300
It fits under the rear floor panel. it closes and locks with tire inside too.
Old Sep 13, 2017 | 08:08 PM
  #89
Ddmccormack's Avatar
2016 GLC 300
E
where did you wind up finding this old spare? Also, did you have to remove the forms below the rear lid to get it to fit?
Old Sep 14, 2017 | 07:55 AM
  #90
mikbar2's Avatar
Won't fit in ours without mods.
Old Sep 14, 2017 | 08:04 AM
  #91
Oliver12's Avatar
GLC 250d AMG Premium
I purchased the official GLC space saver wheel and whilst this is still pretty bulky if the front facing wheel is facing down in the underfloor boot/trunk area- the lower boot/trunk lid almost closes- not quite- certainly better than having the tyre taking up a significant amount of the upper boot area.
Old Sep 14, 2017 | 08:06 AM
  #92
Teckno's Avatar
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
Can you please provide info on the spare you are using ? Model and year it came off, any MB part numbers stamped on the rim, is it steel or alloy.
Basically any info I can use to chase one down here in Australia. Thanks
Old Sep 14, 2017 | 08:41 AM
  #93
Eric_John's Avatar
2011 C300
it is off a 2003 ML. I found it at local wrecking yard for $20 with lug wrench and bolts
Old Sep 14, 2017 | 03:18 PM
  #94
ajmtbm's Avatar
Is it possible to buy one new one fron somewhere or buy one from a 2015 ml?
Old Sep 14, 2017 | 04:30 PM
  #95
mikbar2's Avatar
Is it safe to say that spares should be replaced after 6 or 7 years as your every day tires are?
Old Sep 14, 2017 | 04:33 PM
  #96
dieseldoc's Avatar
I would think you need to change a spare after a period of time just like a ref tire. Risk of dry rot.
Old Sep 14, 2017 | 04:42 PM
  #97
mikbar2's Avatar
That makes Eric_Johns spare 14 years old. Me thinks a fresh RFT might have a better chance of making the 50 miles?? Guess either way is a gamble. Wife had a major blow out on one of her OEM RFT's less than an inch from the corner. It still got her home and me to Americas tires to replace them all at 19,000 miles.
Old Sep 14, 2017 | 09:21 PM
  #98
ajmtbm's Avatar
can you post a photo of what the tire looks like while sitting in the storage space?
Old Sep 20, 2017 | 04:46 PM
  #99
Eric_John's Avatar
2011 C300
Lid closes without having to even push on it
Old Sep 20, 2017 | 10:01 PM
  #100
ajmtbm's Avatar
[QUOTE=Eric_John;7268161]
very nice thanks for posting
is that a US GLC? i dont see the fusebox in there which i assumed would interfere, is it underneath the spare?
