2017 GLC300 - Recall - Pendcurlim (fuse installing) Feb. 28,2017
If you have a situation where the engine cannot be started, due to a hydrolocked engine or catastrophic engine failure, and there are repeated attempts to start the engine, this limiter keeps switching power through the resistor over and over again, causing it to overheat and melt. There is a risk of it catching fire in this situation.
The revised part has been updated to eliminate this possibility, so it cannot overheat.
If your engine starts, you have absolutely nothing to worry about. If it doesn't start and you don't keep trying to stat it over and over again, also nothing to worry about.
I've actually seen one come in that caught on fire on a tow truck, owner had driven into deep water and locked the engine. It arrived with the rear portion of the hood burnt. Insurance company totalled it easily.
