GLC300 Rear differential
Love the car, wonderful piece of machinery.
Right after driving off the lot, we noticed a whining sound coming from the rear when cornering.
Took it into MB service. They were very attentive and agreed the sound was not normal.
After servicing ... this was the story as per the service department
Humming noise coming from rear differential. Found one document about humming noises in drive train when cornering.
TIPS #GI35.31-P-066283. Warm up oil in rear differential, drain oil in Diff. Fill up differential with SPECIAL OIL as per tips document.
Road test, no more noise noticed.
Thoughts?
Thoughts?
I learned that when driving and cornering. if the noise changes gettting louder or shifts to one side of the vehicle you have wheel hub issues. usually the outer bearing. If the whining noise comes from underneath the dashboard or right underneath the Cup holders in the front seats. that is a transmission problem. If the noise seems to be coming from the underneath the vehicle towards center or rear that is the rear differential. In my case .it is a rare differential issue. I bought my car with an extended warranty on it and I do believe it is covered and being replaced right now hopefully. My experience with this noise is that I went out on a quiet country road and sped up to about 65. then Listened to the noise as the vehicle slowed down. I noticed as the gears in the transmission shifted the noise did not change tone it just lowered in tone as the vehicle slowed. This told me it was a gear issue not a transmission issue. The noise would gain in pitch and volume as I went faster and then lower in pitch and volume as I went slower. at 1st I thought it was the brand new tires being very noisy. I hope this information helped you.
