Command failures
alternately, with the map showing, you can use two finger swipe up or hit the middle button at the rear of the touchpad to bring up radio control, then swipe left or right or use knob to change channel. its a 2 part gesture,. which is crazy
agreed a physical button would have been ideal. When map is showing, it would make much more sense if the knob to change the radio and not the map zoom. i rarely change the map zoom. i always change the radio station.
i have gotten used to it, but it is a bit cumbersome and nowhere near intuitive
no voice control i have found for the glc. that sure would be ncie. any idea where i can get the e63 or slk manual, that would probably be a big help as i'm sure many of the commands are similar.
one thing that is oddis that when you change with the steering wheel control,. first push brings up the list and second changes the channel. the two step thing is minor i know but definitely annoying.
