TPMS module and sensor
Old Dec 25, 2017 | 05:56 AM
PickyBoy's Avatar
GLC300 2018
If I want to add a TPMS module and sensor to my GLC. Will the car recognize it as soon as I connect it? What's the part number for the module/sensors? Where the module is located?
Old Jan 3, 2018 | 12:17 PM
PickyBoy's Avatar
GLC300 2018
I guess no one really like/want TPMS
Old Jan 3, 2018 | 11:09 PM
George in KG's Avatar
2017 GLC 300 4matic, 2021 BMW R1200GS
Perhaps you are asking questions best answered by you spending some time with the parts department of your local MB dealer.
Old Jan 4, 2018 | 03:32 AM
Grootkoos's Avatar
Mercedes GLC 250d, Mercedes B200
Why?, Is there something wrong with the TPMS module fitted to your car by the factory?
Old Jan 4, 2018 | 12:53 PM
PickyBoy's Avatar
GLC300 2018
The reason why I want this is because I want to be able to see the actual pressure of each tire without checking them manually. Someone on the forum said, in an other thread, that system that sense the difference of tire pressure is not perfect and won't detect a slow leak right away.
Old Jan 4, 2018 | 02:22 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
What country do you live in. The country you live in will determine type of TPMS system your car is equipped with. In the USA, Mercedes are equipped with TPMS sensors for each tire and allow for individual reads. In other countries such as Canada, TPMS is based off the ABS system and does not give individual reads.
Old Jan 4, 2018 | 07:14 PM
ajmtbm's Avatar
Mercedes-Ben GLC300 4Matic
i have a vehicle with the ABS system and there is nothing worse than seeing low tire and having to figure out which one. thankfully we have the actual pressures displayed here in the US
Old Jan 4, 2018 | 07:45 PM
Tylbran's Avatar
2018 GLC 43 & 2014 SLK 350, gone 2016 E63 Wagon
In Canada, I believe that the GLC300 only has a "tire pressure loss warning system" which gives you a warning light in the instrument panel. The GLC43 has a "tire pressure monitoring system" which shows the pressure of each tire in the multifunction display. It is a great feature which I also had in my E63 wagon. I am not sure if you can retrofit your GLC300 to show the actual pressure (if it did not come equipped with that feature). As George in KG said perhaps a visit to an MB parts department might be in order. Or as an MB service advisor.
Old Jan 5, 2018 | 01:27 PM
PickyBoy's Avatar
GLC300 2018
exact I'm in Canada. They only way that I was able to get it was with the sports package. Thanks I'll contact the parts department
Old Jan 15, 2018 | 10:56 PM
Carphone's Avatar
Former Vendor of MBWorld
W204
Re:
You can check this one for reference:
http://www.gzcarphone.com/mercedes-t...l-lcd_p36.html
After installation, need to use the OBD activator to do the coding.
Old Jan 16, 2018 | 11:40 AM
PickyBoy's Avatar
GLC300 2018
and do you provide an installation manual? if yes are you able to send it to me?
