Ask me anything about the GLC350E
I have had the GLC 350e for approx 1 year now and looking for help. I'm hoping there is a firmware update or something:
I miss my GLK Diesel! The GLC 350e is by far the worst car I've ever owned...not sure why there are no mentions of these major flaws.
I'm locked into this car for another 3 years (got rebate) so need help.
Thanks,
Jordan
- Transmission lag - unresponsiveness especially from Reverse to Drive - slow and dangerous
- Bad judder in brakes when cold in morning
- Fuel economy sucks. 20km max in Eco mode and once electric is out, regular fuel economy is terrible. I average 10l/100km, people only driving 20km or under between charges will see incredible fuel savings but as soon as you hit the highway or go beyond, you are driving an extra heavy, gas guzzler. Small tank, so I fill up every 500 km (diesel GLK was very 800-900km)
- I drive in Eco mode which has no torque or power! Sport+ mode is powerful but fuel is about 20l/100, no good. No luck getting out of the way or passing in eco mode, very dangerous lag as well.
Thanks,
Jordan
I would take this car back to your dealer asap. My 350e dates from Feb 2017 and I have not experienced any of these symtoms. The worst problem I have had is windscreen wiper judder. With a daily charge and driving in Comfort mode, I usually get 900km+ per tank.
Wow. Maybe there is a big difference with the North American Models? I charge every night and it shows 21 km range but usually dies in Eco mode or Comfort mode by 17 km. Then the fuel economy is terrible. Never got more then 500km. But, if you drive 20km total everyday, you can do 900+km without refueling.
You don't have any transmission lag? Or brake judder in the cold/wet? I'm just used to it now.
I will take it in, but I know they won't be able to do anything.
Couple of questions about e-mode in the glc 350e:
1) Does it remember the e-mode setting? I.e.: if you choose e-mode for a drive home from work, plug it in overnight, and get in the next morning, will it still be in e-mode, or do you have to select that every drive?
2) How is the power while in e-mode? Sufficient to get around town?
Considering this for my wife when her bmw lease runs out - typical commute for her is about 8 miles a day round trip, and would be nice if it would just stay in e-mode until we take it out of town.
Answers to your questions
It does not remember last mode. Always returns to Comfort mode. I asked MB about this and there is no way to change this behaviour.
Power in eco mode is sufficient. Very poor response to acceleration and changing from drive to reverse etc. It’s a 100 hm motor that will switch to gas when needed. You will get about 20 km between charges.
#32
Follow-up questions about comfort mode then: what is the default comfort mode behavior like with regard to ev abilities? e.g.: on vehicle start, does it immediately fire the engine to warm it up/let you know it's on, or does it just turn the systems on and operates as an EV until it decides combustion is required? Further, what's the comfort throttle threshold like for running only on electric (i.e.: can you keep it in electric mode by being gentle on the loud pedal or will it basically just run the ICE most of the time and only run on EV mode downhill/stopped/an ant's worth of pressure on the throttle)?
Thanks again for the quick response! We have a few more months before we need to start driving things, but just wanted to start researching now to see if any of the plug-in versions are worth it.
#33
Comfort mode will use electric until you put your foot down harder. It is primarily electric until it needs to start up the engine for speed etc as you mentioned. Yes, you can stay in electric if you are gentle on the throttle. There's a very easy switch on the console to quickly switch to E mode or Sport, Sport +. There is haptic feedback when in e mode to tell you that the combustion engine is going to go on unless you slow down.
Make sure to test drive it. It is NOT a high-torque experience (in E or C mode) like Tesla...quite the opposite. I didn't test drive it, because I just wanted the government rebate to bring down the price. If I had, probably would not have purchased. In cold temps, battery only lasts 15-17 km. Warm days it's 18-21 kms. I don't believe MB did a good job with this car. It needs a major s/w update to fix the lag between drive and reverse. Brake shudders when cold. Powerful only in Sport mode which defeats the purpose of a EV. Also, I don't find it does a good job with Hybrid. It uses mostly E until it runs out then all gas. Highway driving is 100% gas and it doesn't do a good job charging itself enough like Toyota (I have a Highlander Hybrid, non-plug in which drives much better,.). Test drive it and makes sure you are happy with it.
#34
2) Power in e-mode is pretty decent in the first 40% of charge, then it starts dropping off...especially when you get towards the bottom 20-30%.
The range of the battery also depends on whether your commute includes steep hills and freeway driving, and whether you do hard accelerations.
On drives at highway speeds or going up steep hills, I usually switch to e-save mode to later use the charge for lower speeds around town.
#35
2019 model E-mode not available even when showing 100%
Hey guys, I’m trying to resurrect an old thread, does anyone have issues to choosing the E-mode? Sometimes, even after a charge and the battery shows 100%, I’m unable to to see the E-mode as it’s greyed out. Thanks!
#38
Yellow Malfunction message with "gear icons"
[QUOTE
=2498luis;7383115]
I just took ownership of a GLC350e and im willing to answer any questions regarding the car feel free to ask
Plus a couple pics of the car in the dealership[/QUOTE]
Our vehicle has had many issues that seem to resolve on their own or have to be serviced. Most recently the display area turned to yellow words that said Malfunction and had two gear looking icons. Mercedes service department has never seen this before. When driving there is a jerk or jerky transition when this light appears and then the vehicle will not pull from the charge it has. It seems to be something with the going between the hybrid mode and the gas mode. It is at Mercedes now and they are trying to figure it out .
any thoughts?
=2498luis;7383115]
any thoughts?
1500GLmann (11-12-2021)
#39
Does it drive like a car or suv? Easy to drive short distances around suburbs with lots of parking lots & parallel parking?
does it feel big coming from small sedan? Debating between GLA, GLB & GLC thx!!
#40
go test drive a glc300 and glc350e should be more smooth and quiet.
sharifshopping (08-31-2021)
#41
GLC 350e x253 2017 Problem
Hi
I hope you will be kind enough to assist me regarding my 2017 GLC 350e X253. The dealer here in Iceland (Askja) has not been able to solve my problem to this moment. Dealer has been wery helpful regarding this matter bu they seem not to be able to solve the problem. The problem is as follows: When vehicle changes from electric drive to combustion engine drive the displey on the dash shows gears and word Mailfunction. A code P06E900 shows refering to starter problem. The starter has been remowed and tested at a starter repair shop for performance under load and all ok. After the mailfunction light shows up the vehicle dose not perform stop/start function but drives normal.There is also another code showing U301700 battery managment system (BMS) The dealer staded that this code is not related to the problem. I hope you can help me solve this matter or provide additional testing. I know it is difficault to repair through email put please give it a try.
Best regards, Stefan Kristjansson
#42
Hi
I hope someone will be kind enough to assist me regarding my 2017 GLC 350e X253. The dealer here in Iceland (Askja) has not been able to solve my problem to this moment. Dealer has been weary helpful regarding this matter but they seem not to be able to solve the problem. The problem is as follows: When vehicle changes from electric drive to combustion engine drive the display on the dash shows gears and word Malfunction. A code P06E900 shows referring to starter problem. The starter has been removed and tested at a starter repair shop for performance under load and all ok. After the malfunction light shows up the vehicle dose not perform stop/start function but drives normal. There is also another code showing U301700 battery management system (BMS) The dealer stated that this code is not related to the problem. I hope you can help me solve this matter or provide additional testing. I know it is difficult to repair through email put please give it a try.
#43
Question for the group as I couldn’t find the direct answer. Is there a drive mode setting where I can charge the PHEV battery with the motor, not just the brake regen feature. We travel up and down I5 to SoCal once a month and it would be nice to charge the battery up on these long stretches of highway. Thank you guys in advance. FYI, we have a 2020 GLC 350e. It does not have a “charge mode” as one of the drive modes.
#44
You can also switch to "save battery" mode after the battery goes down to 90%, the battery will be kept in same level
#45
drive like comfort, eco and sport are different thank hybrid, esave and the charge mode, which is in the hybrid menu. You have to have it.
#46
TIA!
#48
Yes, the issue persists irrespective of comfort mode.
I can start my trip on EV mode and once it switches over to hybrid (the haptic pedal appears to be turned off) I am unable to switch it back. Sometimes it will even continue after I restart the car if I stop for a short period of time, for example picking up or dropping off the kids.
#49
#50
maybe you just need a system reboot.
