MOE vs Run Flat
Old Mar 14, 2018 | 06:28 PM
kpblade's Avatar
GLC 300 4matic
MOE vs Run Flat
I had seen the term MOE, but never really knew what it exactly meant. I have also seen it use interchangeably with "Run Flat". Found this on the Tire Rack website and though it was interesting info,
https://www.tirerack.com/tires/tiret...jsp?techid=234
Old Mar 15, 2018 | 02:29 AM
Ian of Sydney's Avatar
GLC, Q7
MOE or MO simply means the tyre meets Mercedes specifications.
Old Mar 15, 2018 | 11:56 AM
kpblade's Avatar
GLC 300 4matic
Yes, but the MOE does not meet the international specification for a run flat.
Old Mar 15, 2018 | 11:12 PM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
The Pirelli Verde all season tires that came on my GLC have embossed on the sidewall both terms...MOE and run flat.
This situation is confusing as its been written an MOE tire does not meet the engineering criteria of a run flat tire. If this is the case, how is it the tires on my GLC contain both terms? My guess is, there is a difference in construction between an MOE tire and a run flat tire, however, that difference is so slight as to be insignificant. Therefore, it seems possible an MOE tire and a run flat tire could be considered interchangeable.
Old Mar 15, 2018 | 11:50 PM
DDGator's Avatar
2021 GLB 250
My understanding is that "run flat" tires have to be able to run 50 miles at no more than 50mph without any tire pressure. MOE tires have to run at least 20 miles. So a run flat tire could also be MOE -- it just exceeds the MOE requirmeents.
