GLC300 cooling systems
Old May 26, 2018 | 02:06 PM
mikbar2's Avatar
2015 C300, 2015 F-350 Platinum, 1969 Mach 1 428cj, 2007 Roadking
Do the primary and secondary cooling systems use the same fluid? The two systems in our 2016 appear to have different colored fluids.
Old May 28, 2018 | 05:16 PM
George in KG's Avatar
2017 GLC 300 4matic, 2021 BMW R1200GS
please explain what you mean by secondary cooling system. I have never heard that term before in relation to a car.
Old May 28, 2018 | 07:29 PM
mikbar2's Avatar
There is an expansion bottle towards the front of the engine bay that contains the radiator coolant. There is another expansion bottle towards the rear of the engine bay with the same type of cap. Is this coolant for the turbo or some other type of fluid with a different purpose?
Old May 29, 2018 | 10:27 AM
decorily's Avatar
GLC 300d 4matic
Photos would help.
Are you sure you are not confusing your coolant with your windscreen washer fluid?
Old May 29, 2018 | 12:33 PM
mikbar2's Avatar
Originally Posted by decorily
Photos would help.
It's the round cap at the top left/center of the pic by the fire wall.
Old May 29, 2018 | 02:39 PM
Sigp232's Avatar
2021 GLE 450, 2017 GLC 300 4Matic, 2008 FJ Cruiser
Been bugging me to what is the reason for I guess a second coolant? When I go to dealer I always forget to ask him what it’s for.
Old May 29, 2018 | 06:15 PM
mikbar2's Avatar
On my pick up truck the secondary cooling system is for the turbo and egr cooler, however they use the same fluid.
Old May 29, 2018 | 06:51 PM
decorily's Avatar
GLC 300d 4matic
My 250d does not have this reservoir as referred to above. It does however have one located in what would be the lower right side of the photo above.
Old May 30, 2018 | 08:40 PM
Tylbran's Avatar
2018 GLC 43 & 2014 SLK 350, gone 2016 E63 Wagon
My 2018 GLC43 only has one reservoir for engine coolant (similar to what is seen at the front left of your picture). I suspect the other reservoir is for brake fluid? My engine does not have the same cap at the back of the engine that is shown in your picture. Is the cap that you show connected to a pressure type container similar to the engine coolant container shown in your picture or just a reservoir?
Old Nov 24, 2022 | 04:59 PM
gaby10026's Avatar
GLC300
My car have the same as this picture. I’m wondering the small one connects to turbo.
Old Nov 25, 2022 | 09:40 AM
edpare's Avatar
2020 GLC300 touring version (but I miss my '93 300SE W140 tank)
The blue cap covers the wiper fluid reservoir in my 2020 GLC300
Old Nov 26, 2022 | 07:14 AM
4npower's Avatar
2019 GLC 63, 2020 C43 coupe
It's the expansion tank for the low temperature cooling circuit, or as some others have said, the coolant for the intercoolers and probably the transmission as well. The cap even has a little radiator on it like the other cap from the high temp circuit. Pretty much every modern turbocharged Mercedes has two separate cooling systems.
Old Nov 26, 2022 | 07:22 AM
4npower's Avatar
Your 2nd/low temp coolant reservoir is slightly under the left side engine cover in front of the oil cap. If I recall.
Old Nov 26, 2022 | 11:56 AM
GeneS's Avatar
2022 GLC 300 RWD
May I ask, what does the red slide do on the left almost rear of engine bay do?
Old Nov 26, 2022 | 12:07 PM
W205C43PFL's Avatar
You open the cover to expose the positive terminal to jump start the battery.
Old Nov 26, 2022 | 06:34 PM
GeneS's Avatar
2022 GLC 300 RWD
Thank you
Guess you can tell I'm new to the GLC300
Old Nov 26, 2022 | 08:10 PM
W205C43PFL's Avatar
Thank you
All good, ask away : )
Old Nov 26, 2022 | 08:24 PM
mikapen's Avatar
Thank you
Welcome!
Old Jan 21, 2024 | 07:49 PM
RA040624's Avatar
GLC
That's a good explanation. I have a 24 GLC and yes they do have a split cooling system. Pretty sure most modern 4-cylinder turbo engines are designed that way now. Looking at the fluids it appears that mine has the exact same type at least by color, not sure how it's diluted if at all.
Old Jan 24, 2024 | 07:08 PM
wireman218's Avatar
2022 GLC 300 4 MATIC
2022 GLC 300. I think it's a M264 engine 2.0L
Only oe cap and expansion tank.
Old Apr 7, 2025 | 09:49 PM
David Broughton's Avatar
2017 Mercedes GLC300
Curious about this on my 2017 GLC300
If the smaller expansion tank for the intercooler is empty with the car off should it be filled with the same coolant as the larger engine cooling reservoir?
Also, is there an indicator for max fill on the smaller expansion tank?
Getting a P0128 code from the OBD2, could the low level of coolant in the smaller expansion tank be the culprit? Or would that only relate to the engine cooling system?
Old Apr 7, 2025 | 10:51 PM
4npower's Avatar
Yes, same coolant as main reservoir.
When you take off the cap to the smaller reservoir, there should be a plastic "T" or "X" that you can see sticking up straight in. Fill coolant to the top of the plastic. Approximately 1" below the cap.
Yes.
Old Apr 8, 2025 | 12:03 AM
Is it common for this coolant to be low over time or does it being low automatically mean there’s a leak somewhere?
Old Apr 8, 2025 | 06:51 AM
4npower's Avatar
No, not normal. You may have a small leak or a rock puncture in your intercooler radiator. Depending on how quick the level drops after refill, will tell you how big the leak is.
Old Apr 8, 2025 | 01:44 PM
mikapen's Avatar
I lost coolant due to an improperly tightened coolant cap.
I first noticed it while off-roading on a steep descent. Warning light.
I didn't even know what the correct fill level was. It's not a mark on the tank - it's a peg-like protrusion from the bottom of the tank.
Now I know how to check when the engine's cold.
