Help: will re-painting two of the doors match the original color ?
Someone maliciously scratched my GLC's doors on the driver's side in a public parking lot.
The body shop told me it needs $2500 for the repair. Basically they would first remove the original paint from both doors on the driver's side, and then re-paint again. The whole process takes a week.
Though my insurance company will cover most of the repair cost, I am scared to learn that they would remove the original paint and repaint again. My question is, could the re-paint match the original color exactly the same (as the other portion of the body)? My car's body color is metallic gray.
I appreciate if you could share your knowledge and insight.
Thanks in advance,
Typhooonn
Luckily, you can remove the doors and not worry about blending - it sucks when they have to paint part of a panel and then blend the colors!
Check with your insurance company to see how they will guarantee this if they can (i.e. will they allow for re-do if no match). When looking to match, get it out in noon daylight to check. In theory, you should not expect an issue - most of the process is very modern these days and the color match should be exact.
