My first 9,000 kms with the 2019 GLC300 4 Matic
Almost about to introduce the 5th digit on my odometer, time for an update ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Interesting observation happened the other day, we had rain, snow, sleet all within a few hours of each other and my two front windows froze shut....
The temps were not that low below zero maybe only 1 or 2 degrees, so pretty warm still, not enough to normally do this. My thoughts are that the motors are unusually weak, or that the tolerances are very tight with the windows and sill ( most likely reason for noise abatement and cheating the wind)
Luckily it happened when I was not going to Timmies or that would have been catastrophic![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
So when I tucked her in for the night, I left the aux heater on, to melt the ice overnight.
Next morning windows opened fine she is a balmy 1.5 degrees in the garage.
I put all the windows down and you could see all the streaking of water on them ( felt liners is my guess) so I then drove to air dry them and repeated it after a Timmies visit of course, and then windows had little H2O left behind after this running them up and down a few times and letting the airspeed dry them.
Just a quick note for all of you, I wonder what would happen when winter comes and it gets cold out![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Also had a new warning come up on the dash..." Sensors dirty cruise control not working" or something to that effect.
This shows a serious failing of the system having only a single access cruise control vs a two stage one, for Mercedes its embarrassing, when "lesser" cars have it.
Interesting item is though I never cleaned the cameras and it has worked for a week now, so testament to the sensitivity of the units, top marks there.
Are my windshield wipers getting quieter?....shhhhhh![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Shifting into reverse still needs a two pump or long hold....
The ABS was called up the other day, she worked fine, however I was surprised on the all season tires and how they did not like skating that much, maybe I did not get the Canadian version?![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
Got to get my rims figured out getting different feedback on offset, etc... Got the Michel Xice 2's ready to roll.
See you at 10k
See you at 10k
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
