Door Hinge
I'm having a Guinness or two later....I'll put it on your tab!
grabbed a socket, and 2 minutes later we had a smooth and silent door! Much appreciated sir.
Fast forward 6-8 months and it starts creaking again, probably due to the hot and cold climate here in Toronto, that bolt is getting loose or its just not holding tight. Anyways, I called the indy and they said some **** about warranty and they may be able to cover the parts because its genuine OEM but I would have to pay for the labour. I scoured the internet to learn how to remove the door panel and do it myself as I thought it was the hinge again, but I found this.
My god, literally 5 minutes and a socket set and the noise is gone. I am sitting here thinking to myself I could of saved 5 bills last year by trying this first. Thank you so much, I truly appreciate you posting this, you're a MVP.
2nd dealer confirmed popping and replaced hinge under warranty 11/2020. 10 months and 3500 mIles later popping resumed. A hard twist with a 7mm wrench and quiet again.
Do you all have problem only on driver door?
Thank you so much for these posts!
