Door Hinge
Old Mar 10, 2023 | 11:52 PM
user 250729720's Avatar
GLC 250d
Hey GLCMAN. Maybe just go with the spanner until the noise is no longer there. I didn't go any tighter than I needed to.
Old Mar 11, 2023 | 04:45 AM
decorily's Avatar
GLC 300d 4matic
Originally Posted by GLCMAN
Hi, how much are you guys tightening the nut, I mean mine is already just more than hand tight....does it need to be super tight....am afraid I might break something or round off the nut if i put too much force on it?
Maybe it is too tight!
Old Mar 11, 2023 | 03:02 PM
mikapen's Avatar
Try a real door hinge lube.
https://mbworld.org/forums/glc-class...ml#post8736699
Good luck.
Old Apr 10, 2023 | 04:43 PM
ImpliedConsent's Avatar
2018 GLC63S Coupe'
Thank you for this. On my front passenger (US) door. 7mm socket.
Old Jun 26, 2023 | 08:20 PM
megaball24's Avatar
glc300
You are god’s sent. Local shop want to charge $300 for the replacement of 2017 GLC300. Luckily I found this post. 30 seconds to find the 9mm and done
Old Aug 11, 2023 | 10:23 PM
Jim Flick's Avatar
2020 AMG GTC, 2019 CLS AMG 450, 2020 GLE $%)
You just saved me $996. Had my CLS in for the 60k service today and they reported "noisy driver door lower hinge." Wanted $996 to replace, and 2-3 work days. I took a pass on having them fix it and looked at it when I got home. Had some trouble piecing it all together until I found your post. That set screw was only hand tight. I loosened it by hand and the grinding/popping noise in the hinge got worse. I hand tighten it, then put a socket to it and tightened it fully. The hinge is absolutely quiet now. My question is one of trust with the service dept. at my dealership(where I have purchased 5 Mercedes). Why did the mechanic and service dept. recommend a $996 repair when a 10 second screw tightening was the fix? Were they intentionally misleading in order to cash dollars for the service dept? The alternative is almost worse- Are they so mechanically inept they do not know a simple 10 second fix? If this is the case I do not want these folks taking the engine apart on on my AMG GTC. Sheesh!
Old Aug 23, 2024 | 03:37 AM
  #32
leeno's Avatar
mercedes benz 2018 glc300 coupe
DO NOT GO TO DEALER SERVICE CENTRE
The only way to these dealers make money is through their service centres trust me I worked there!! Go on google find a trusted mechanic with incredible reviews and use him!! Mb and bmw will give you the crapp if you use anyone but us you warranty will be voided which is complete bs.. trust me run far away from those service centers they are heartless and could give a crap if it’s an old lady or a mother with 10 kids!!
Old Aug 23, 2024 | 11:34 AM
  #33
mikapen's Avatar
In general and over time, Dealership profits come approximately equally from Sales, Service, and F&I.
Old Aug 29, 2024 | 06:18 PM
  #34
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
Open the passenger side door, 7mm wrench and 2 seconds worth of effort to tighten the adjustment bolt on the lower hinge and no more noisy hinge.
Old Sep 16, 2024 | 03:00 PM
  #35
Tony Paterson's Avatar
A238 E Class Cab E220 Premium Plus 2018, X253 GLC E220 Premium Plus 2018
Thanks guys turned the issue off with your simple fix 👏👏👏👏👏
Old Feb 20, 2025 | 05:26 PM
  #36
Morris 001's Avatar
Thank you so much!
Thank you so much! My 2018 Mercedes-Benz E300 had a metallic clunking sound when opening and closing the driver-side door. I ruled out the door check strap as the cause, and the sound seemed to be coming from the lower hinge area, as if a bolt was loose, but I couldn't locate it.
Thanks to your help, it was fixed in just one minute, saving me a trip to the repair shop. God bless your kindness and assistance!
Old Feb 20, 2025 | 07:08 PM
  #37
decorily's Avatar
GLC 300d 4matic
The interweb may not be such a bad place after all !!
