Adding Disctronic Plus after the fact
So based on that, I was thinking what other components I might need to add the distance controlled cruise control which is the only option I wish I could get. I have seen the long distance radar on ebay for about $450 but I am not sure other than that, what other components are needed to potentially add this.
I also have looked all over to see if I can find the list of components or diagram for this and I haven't been able to find anything.
What do you think? Is it possible to add? If so, what parts would I need?
no you cannot add distronic via dealer nor aftermarket.
But it’s not all bad. While I have distronic and find it great— I suspect most people would find it more annoying to “drive by wire” then to just use pedals and steer themselves. You can’t trust the car on unfamiliar roads anyway.
However, i have read retrofit heads do it on their cars and you will be paying alot just for it and its not worth it
I didnt say it was bad, i just said that i hardly use it lol
1. How is Distronic in stop and go traffic vs regular traffic on highways for keeping you in the lane?
2. Do you need to press accelerator in stop and go traffic when vehicle comes to complete stop?
3. I know branding is same, but is all hardware/software same irrespective of the model - GLA vs GLC vs GLE?
Recently, I tried this on a Toyota (Rav4) and it was horrible. For some reason Lexus was slightly better even though its the same parent company. But with Toyota, you can have aftermarket Open Pilot which is not an option for Benz.
- It's good, although I mostly use it on the freeway I have also turned it on in bumper to bumper traffic because it makes life easier.
- Depends. The system stays active for minute or so (not sure how long) and if the cars start moving again it will follow. You can see when this is active and when it stops in the dash and HUD. Once inactive you need to press the accelerator to make it start moving again but then it auto resumes and you don't need to keep accelerating.
- No idea.
