Car play vs command
Old Sep 23, 2019 | 06:16 AM
C B Corbett's Avatar
MB GLC300
Car play vs command
I am shopping for a 2019 GLC300. Can car play be added and disconnect command through the dealership? Does command allow the use of apps on the car screen?
Old Sep 23, 2019 | 09:38 AM
peet's Avatar
09 C63
With Carplay Comand is never disconnected - rather Carplay runs inside of Comand. That being said, based on older notes there is no TECHNICAL reason I can see why a dealer can't do this. But it's not a standard procedure - as in, buy part number XXXXXXX and pay $YYY and it's in. It's a retrofit. If you need it, I suggest you find a car that has it.
Old Sep 23, 2019 | 12:22 PM
MB GLC300
Thank you.
Old Sep 24, 2019 | 09:00 PM
Chrisk03's Avatar
GLC43, GTI, X3, Mazda3
For a 2019 model you either have CarPlay (Smartphone Integration) or COMAND, but not both. You can’t add CarPlay to a COMAND vehicle...without a lot of hardware changes and a dealer will be little help.
2020 model is a different story...
Old Sep 24, 2019 | 11:27 PM
MB GLC300
Thank you. This was very helpful
Old Sep 25, 2019 | 10:50 AM
peet's Avatar
09 C63
My bad and Chrisk03 thanks for clarifying. I sometimes forget that there is a non-Comand screen. Either way it holds true that you will need to swap a lot of parts or install aftermarket parts with Comand to make it work. When I was shopping it was hard to find a loaded car without Comand. But I wanted carplay and android auto.
