Knocking noise from front
It’s definitely an interior rattle but I can’t for the life of me figure out where it’s coming from, possibly in the dash somewhere!
Hi,
Has this issue been solved? This issue annoyed me seriously too. I tried many different ways to solve it but it didn't go away, I damp the car inside and out, I damp inside tires, I took off the stiffener bars. What was helping me is to turn on the music loud.
Some owners wrapped electrical tape around rear seat lock horizontal bars to take up the slack in the mechanism, this worked.
I am getting car serviced tomorrow, so I have emptied everything, even in doors, glove box and under boot floor.
I had a strange rattle today from the front that might be worth investigating by you.
I had a water bottle in the double bottle holder slot by the consol and there was an intermittent rattle, took bottle out and it went away !!
Seems the 4 x little stability fingers have small ratchet locks and if you press each one in and out they make a rattle noise.
Try no bottles or coffee cups in them and press each one in and out to see if its same noise ?
The only other suggestion is look under car wheel arch at plastic shrouds, if a lock pin had broken or fallen out it could knock when driving. Same with plastic sump guard and air deflectors underneath - could flap under driving conditions.
Good luck.
