Installing LED Lights on '20
Old Jun 22, 2020 | 03:45 PM
KCSam's Avatar
GLC
Hi, guys. I just purchased a '20 GLC last week (will be delivered tomorrow). I'm interested in purchasing some LED lights to swap out the yellow tinted ones for the interior and license plate. Has anyone replaced any or all of these lights on a '20 yet? Is there anything special or specific I should know prior to replacing the lights? I've replaced all of the lights before on my Mazda CX-5, but not sure if the job on a Mercedes is as easy. Any info would be appreciated. Thanks
Old Jun 22, 2020 | 06:39 PM
decorily's Avatar
GLC 300d 4matic
Aren't the interior lights LED as standard?
Old Jun 22, 2020 | 07:00 PM
KCSam's Avatar
GLC
Are they? I didn't think that they were, but like I said, I don't have the car yet and when I test drove it I thought they were standard yellow. Does anyone know for certain? If so, I won't waste the money ordering tonight on Amazon.
Old Jun 22, 2020 | 07:52 PM
huni1649's Avatar
GLC350E
It was installed at 2020 GLC in my shop in Korea.
Old Jun 22, 2020 | 10:05 PM
KCSam's Avatar
GLC
That's the ambient lighting. I'm talking about the dome, backseat, glove compartment, vanity and rear view mirror lights. I don't think those are white LED, are they?
Old Jun 22, 2020 | 10:52 PM
ItalianJoe1's Avatar
2003 CL 600
They are LED from factory in my '18, i'm sure the 20 is too
Old Jun 22, 2020 | 11:23 PM
KCSam's Avatar
GLC
I would think that would be so. I'll hold off on ordering and see for myself when the car is shipped. Thanks for the response.
Old Jun 23, 2020 | 01:50 AM
wkc987's Avatar
mazda3
I think they are LED, but they are in warm color by default. ie, yellow color.
Old Jun 23, 2020 | 09:32 AM
KCSam's Avatar
GLC
You can change the colors of the dome, back, rear view mirror lights, etc.? I thought you could only change ambient lighting colors?
Old Jun 23, 2020 | 10:25 AM
decorily's Avatar
GLC 300d 4matic
No.....unless you buy new replacement 'bulbs' as the OP was intending.
Old Jun 23, 2020 | 10:31 AM
KCSam's Avatar
GLC
The OP was me. If they are LED, but yellow, then I'd want to switch out for white LEDs. Has anyone switched out the interior lights?
Old Jun 23, 2020 | 10:42 AM
decorily's Avatar
GLC 300d 4matic
The OP was me.
Oops....apologies.
I suppose it depends on how exactly you define 'yellow'! I find the interior lights to be very bright and effective....then again I have the cream seats and headliner which probably makes the interior look brighter than a black interior would look.
Old Jun 23, 2020 | 10:50 AM
KCSam's Avatar
GLC
Oops....apologies.
No problem.
Yeah, mine is black seats with crystal grey headliner. I recall it looking very yellowish. Not sure why they wouldn't put in full white LED's in the cabin.
Old Jun 24, 2020 | 01:37 PM
Daniel6L's Avatar
W220
No problem.
Definitely has LEDs inside. I prefer the warmer color rather the whitish/blue LEDs in my old RX350. It gives the cabin a warmer, more inviting feeling. If you evaluate indoor lighting, usual a warm or soft white (2700k) is used for more bedrooms while a whiter (5000k) is used in work areas
Old Jun 24, 2020 | 01:56 PM
KCSam's Avatar
GLC
Thanks for the response. I'll check them out and see if I am fine with the warmer color vs the white LEDs I was contemplating purchasing. If I do go that route and want to replace all of them, I'll need to find out how much of a job it is. Hopefully it's just as simple as popping off cover/housing and snapping lights in.
Old Jun 24, 2020 | 02:11 PM
decorily's Avatar
GLC 300d 4matic
[QUOTE=KCSam;8089741
Hopefully it's just as simple as popping off cover/housing and snapping lights in.[/QUOTE]
Highly unlikely!
Old Jun 24, 2020 | 02:14 PM
KCSam's Avatar
GLC
Highly unlikely!
Uh oh.. This is my first Mercedes, so I'm assuming they are NOT the easiest to work with?
Old Jun 24, 2020 | 04:22 PM
wkc987's Avatar
mazda3
I dont think is pop and replace too. Especially the light in the center light control area. I remeber the car has 4 led bulbs inside the transparent cover there. I am not sure if they are one strip or individual bulbs inside. Also I remember the reading lamp seems to be integrated in the rearview mirror as well. I may be wrong because I am still waiting my Glc to arrive.
Old Jun 24, 2020 | 04:25 PM
KCSam's Avatar
GLC
I'm still waiting for mine to arrive, so I'll have to check it once I get it. I've read that the review view mirror and license plate lights aren't easy and require disassembling.
Old Jun 24, 2020 | 09:38 PM
2003 CL 600
None of them are removable bulb LEDs, and will require soldering the chips off the board to replace with a different color.
Old Jun 24, 2020 | 10:41 PM
KCSam's Avatar
GLC
Oh wow. Good to know. I had no idea about that. Thank you for the info. I'll save my money and not buy the replacement bulbs.
Old Jun 29, 2020 | 12:46 PM
ParjAS's Avatar
19 GLC300 4M (lunar blue/black/black ash aluminum),17 GLE350 4M (selenite grey/ espresso/eucalyptus)
Ideas
I see that they are kinda yellow. I think it looks better on magma gray which I have and beige. White bulbs otherwise, but reconfiguration must be done, bulbs are not removable.
Old Jun 29, 2020 | 12:50 PM
KCSam's Avatar
GLC
That's too bad because I was looking forward to switching out the yellowish lights for a more white tint. I guess that's one job I will not be partaking in. I'll just leave them as they are.
Are none of the bulbs removable throughout the entire interior? Back seat, glove box, etc.?
Old Jun 29, 2020 | 02:40 PM
ParjAS's Avatar
led
I know the vanities are not removable neither are the trunk lights. Others I'm not sure.
Old Jun 29, 2020 | 02:45 PM
KCSam's Avatar
GLC
Sounds like none of them are going to be. No problem. I'll just keep what I have.
