HELP! UPGRADE STATIC LED TO CHINA DYNAMIC LED HEADLIGHTS
Hi has anyone purchased the headlight upgrade from static LED to dynamic LED?
Help is much appreciated on installation. Out of options what to do next... not plug and play.
China headlights from BETA, it comes with control units and they’re not interchangeable with my original headlights and the connector plug pin-outs don’t match my car’s connector plug.
My cars static LED wiring:
Pin Usage
1 CANbus network
2 Side-marker
4 Low current turn-on signal
9 High power +12v feed
10 Ground
I bought these China headlight China headlight China headlight
China module OE vs China module Cars connector plug Cars connector plug (1,2,4,8,10) China headlight connector plug 6 PIN (2,3,4,5,6,7) China module connectors
Yes, supplier says they’re suitable. Headlights are advertised and labeled as upgrade Static LED to Dynamic LED but supplier is double checking with manufacturer. Should hear back shortly...
