Need help with Radar Detector
Old Apr 6, 2021 | 06:25 PM
lbraga65's Avatar
c300
I have a 2020 GLC 300 and I am looking to install a radar detector. Valentine 1 comes with the hardwire kit but I am thinking to tap into the rearview mirror. I tried searching youtube and I am not able to find any videos on how to. I want other people's opinion on best and easiest method to install the radar. I also have a lease so will need something that i will be able to undo when lease is over.
Old Apr 7, 2021 | 07:27 AM
lbraga65's Avatar
c300
anyone know?
Old Apr 7, 2021 | 07:50 AM
midesaka's Avatar
2017 E300 Sport, 2017 GLC300 Sport/Night
I had my V1 (Gen 1) installed in my 2017 GLC 300 by a local stereo shop. They tapped into the driver's side fuse box and ran the line up the A-pillar, and also hid the V1 Connection LE Bluetooth module in the driver's side dash. Everything is hidden except the RJ11 connector, which peeks out of the trim at the top of the windshield near the mirror.
Old Apr 7, 2021 | 08:30 AM
lbraga65's Avatar
c300
Cool I was not sure which side the fuse box i can install on. I will take a look.
Old Apr 7, 2021 | 10:39 PM
Jcrew's Avatar
SL 400, GLC300, C300
I installed my Escort detector in my GLC 300 after reading about the hardwire install on this forum. It was actually quite easy.
Here’s the link:
https://mbworld.org/forums/glc-class...-2020-glc.html
Old Apr 18, 2021 | 05:10 PM
lbraga65's Avatar
c300
did you connect to the fuse box or mirror tap? do you know what this purple device is?
Old Apr 19, 2021 | 08:25 AM
Jcrew's Avatar
I don’t recall what the purple module is (although I think I looked it up at one time).
I did not wire directly to the fuse box. I figured, why bother. That’s what the mirror tap is for.
I tapped in to the two wires for the mirror and it worked perfectly.
Old Apr 19, 2021 | 09:46 AM
lbraga65's Avatar
c300
was it you that spliced into the wire?
Old Apr 19, 2021 | 09:54 AM
Jcrew's Avatar
No. There’s no need to splice if you buy the tap kit. It’s a simple pin insertion to the connector.
Old Apr 19, 2021 | 10:10 AM
lbraga65's Avatar
c300
yea but what wire you talking about because I did not see a specific wire that goes into the mirror? I see like 3-4 modules so I tapped into the purple one. Issue is that it is active even when powered off. All others I checked are the same.
Old Apr 19, 2021 | 10:32 AM
Jcrew's Avatar
You might want to read the other thread that is referenced above. It contains a lot of useful information on which wires to use.
Here’s a pic of the wires that I used. Hope this helps.
I used the green (+) and the brown (ground) and inserted the pins from the tap kit into and alongside of those wires where they entered the connector body.
Old Apr 19, 2021 | 12:49 PM
lbraga65's Avatar
c300
ah ok i think i saw that before. does it only give power once car is on or all the time?
Old Apr 19, 2021 | 01:01 PM
Jcrew's Avatar
Power is present as soon as your door or hatch is opened or unlocked. Power is removed shortly (maybe a minute or two) after you lock the car via touch or fob.
