Service B include Road test / Pothole Special
Old May 25, 2021 | 09:26 AM
ari_s's Avatar
2017 GLC 300 4Matic
Hi Folks,
My 2017 GLC is making a bit of noise and the ride is bumpy recently. The car is a Certified vehicle and under CPO Warranty with about 28 k mileage and last serviced in Oct 2020. I am not sure of the reason and upon calling the dealer they suggested a full inspection for 199$.
My question is if I get them to do a Service B now will that include the road test?
Also, the dealer have a 189 $ pot-hole special in their website which includes Wheel Alignment, Tire rotation, inspect wheel, reset tire pressure - should I get that instead?
Thank you.
Old May 25, 2021 | 11:30 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Not actually knowing your car. I would first suspect your tires if they are the ones that came on the car. Also, which I cant remember isn.t 30,000 a A Service. They normally do a courtesy check on any A or B service. Every time I take my Mercedes in for service A or B, I get a read out on tires depth, remaining brake wear and then anything they find that they think I should have fixed. Make sure your Service Advisor reviews them with you. Not sure about the drive, but they should include this, especially if you have an issue. don't pay the 199 just get a Service A.
Old May 26, 2021 | 09:19 AM
High Technology's Avatar
2020 GLC300 & 2009 SL550 (previously had 1999 CLK / 2006 E500 / 2011 GL450)
The most frustrating thing a service writer or a service tech wants to hear is the vehicle is making a noise. More than half of the time, the response back will be "cannot duplicate customer concern". In other cases, the noise is something that the customer caused, usually an item in the cargo area.
So, speaking from experience, I know that I need to give the dealer very specific descriptions of how to duplicate the noise. So drive the car for a few days, and see what combination of circumstances can usually / always duplicate the issue. Things like:
Speed -- high or low
Bumps -- over uneven pavement, potholes, speed bumps, etc.
Steering - when the wheels are turned or not
When the car is warming up vs. warmed up
.etc., etc...
When you have figured out the best combination, then go to the dealer --> this will ensure they find the problem, which if under warranty will not incur a diagnostic charge. Usually the dealer will waive the diagnostic charge if you have it repaired by them if not a warranty item (e.g., you ran over a curb and damaged a suspension component).
Old May 27, 2021 | 05:23 PM
ari_s's Avatar
2017 GLC 300 4Matic
Thanks for your replies. I went to the dealership today and the folks where kind enough to run a diagnostic test and a road test without charging me anything.
Here are the comments from the service advisor - my front tire is 5/32 (L), 4/32 (R) and rear are 9/32 (L - this was replaced last year as I hit a nail) and 5/32(R). They said I can continue driving safely and if the noise is an annoyance they can replace the front right tire (which is 4/32). I thought Mercedes recommends changing tires when the tread is below 5/32, any suggestions are welcome.
Thanks very much.
Old May 27, 2021 | 05:49 PM
mikapen's Avatar
Thanks very much.
That's good feedback.
I don't know what M-B recommends but I start shopping at 5/32, and replace at 3/32".
I start getting aquaplaning at 4/32, and I don't like going into winter with less than 5/32.
So my replacement schedule is season dependent.
I think the wear bars are set at 2/32.
Old May 29, 2021 | 03:40 PM
stath's Avatar
2018 GLC300 P01 selenite grey
Also, another possible cause is the updates to the software for suspension, and maybe transmission. Many Benz drivers had reported bumpy rides and steering wheel vibration. In many cases after the software updates for suspension and transmission the problems went away.
These cars are highly computerized and updates to software and firmware are very crucial.
