what are you "must have" appearance options?
Old Aug 16, 2021 | 04:04 PM
hcoronado's Avatar
2021 GLC300 4Matic
Originally Posted by KCSam
The grille looks really good. Did you do yourself? I talked to the parts people at my shop and they said they don't have any part numbers for what is needed to go from my current grille to yours. Any info you can share on how you got yours would be much appreciated.
I did the Grille over the weekend after extensive re-search "did not want to buy the wrong part"
https://www.ebay.com/itm/254748457293
it arrived pretty fast to the S.F. bay area but item came from Los Angeles.
The Grille is not difficult to replace, All I had to do was remove all the retaining plastic pins and two hex bolts that hold the upper part of the bumper to the chassis.
I followed this video instructions and it was pretty on point
I've seeing videos where they remove the entire front bumper and that's is fine but that is a lot of work. All you have to do is be careful with the tabs and your hands but definitely take your time. it helps to have a big and small flat screw driver to press on the tabs but take your time.
I removed the grille but disconnected the sensor plug that is behind the MB Star first and once the grille was out I removed both the sensor and star bracket and installed on to the new one.
Old Dec 22, 2021 | 02:52 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
bump for grill install video....
Old Dec 27, 2021 | 05:04 PM
KCSam's Avatar
GLC
https://www.youtube.com/watch?v=0ZFlaDZY4ps
And it all fit the same as your original grille? I'm asking because I am about to purchase the same grille you did, but want to make sure it fit perfectly and you didn't need any additional parts for correct fit. Is your GLC a 2020? If so, then everything for yours should fit the same for mine when I order the grille.
