Need Help CV Joint boot kit part number
Hi friend , My 2016 GLC300 4matic front axle shaft inner joint is leaking GREASE Dealership quote me $2110 to replace it. So I decided to replace the boots myself but not really sure about part number, any information will be really appreciate and thank you in advance
I triedI Rtv gasket maker to cover the pin hole. Failed. Rtv does not stick hard to the boot rubber. So leaked again. I tried silicone base glue. Same fail.
Finally I used an electric soldering iron to melt the rubber 1mm depth around the pin hole. That worked.
Boot part number
Pin hole leaking grease
Cv axle part number
I found pin hole and leaked grease around the boot.
Boot part number
Cv axle part number
Boot part number
Cv axle part number
Rubber boots not tear but found a pinhole
My boot leaked again from the somewhere under the metal clamp.
I put silicone gasket maker rtv. But leaked again because not really stick to the rubber boot.
I bought "polyurethane base flexible" caulking, and seems work well now.
