Wheel Fitment Question: 2018 GLC 300
Hi All,
I'll shortly be in possession of a 2018 GLC 300. Will the following wheel/tire combo fit? I tried doing a search but unfortunately couldn't find too much.
20X9, 5x112, 27mm offset wrapped in 255/45/20.
This was the winter setup on my M40i that's going back to the dealership and it would be ideal if I could use them on the GLC as well.
Thank you,
Thank you,
https://www.wheel-size.com/size/mercedes/glc/2018/
If you scroll down to the GLC 300 you'll see one of the stock size options is a 255/45/20 on 8.5Jx20 ET40 wheels. Your wheels are a half inch wider, with about a half inch less offset (aka pushed out).
My guess is, size-wise they would work fine, assuming the the mercedes lug bolts seat properly in the wheel (ball seat vs cone seat), and assuming the hub bore is the same at 66.6
