Spark Plug mileage
Spark Plug mileage
My 2020 GLC300 has 57,000 miles on the odo. Runs and rolls better than the day I bought it. My SA suggested new plugs and I turned her down. What does M-B say about maximum spark plug age?
Received 2,486 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
mikapen (05-28-2024)
When I replaced plugs at about 100,000km. Nothing was wrong. I thought i could drive on original plugs for another 100,000km.
For Coils, don't waste money until you see misfire codes. Probably never.
Im going to replace coils at 60K miles, recently I pulled the plugs to inspect cylinders and coils do look old and tired to me. No missfire.
Attachment 453924Attachment 453923
50k miles.
mine looked like they needed it on both cars with the same engine.
the injectors fire multiple times per cycle which wears them earlier. Also, corrosion can be a problem and you don’t want plugs getting stuck and breaking in the head. It’s dissimilar metals with electricity going through - galvanic corrosion will eventually become a problem.
get em changed if you’re keeping the car an extended period of time.
Originally Posted by Camaroguy72
50k miles.
Received 1,604 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
50k miles.
There is an awful lot of threaded portion between the combustion chamber and the sealing surface outside. Pretty impossible to keep it sparkling clean forever.
The benefit is that for $162 for 4 Bosch coils from FCP Euro, you will likely never have to worry about them again. Nothing more than cheap insurance for me on an engine that is perhaps worth $15,000. You already have the coils unbolted and nearly out when you do the plug swap as it is. Just good science. But my suggestion won't matter, 98% will just wait until they fail and misfire their engine - and that is their choice.
