View Poll Results: Fuel guage not working
Fuel level sensor
1
50.00%
Sam module
0
0%
Fuel pump
1
50.00%
Voters: 2. You may not vote on this poll
2017 GLC 300 Fuel gauge not working
Old Jun 30, 2025 | 12:18 AM
KingWeston's Avatar
2017 GLC 300 Mercedes Benz
Hey am new here really need your help on this after so many attempts my 2017 GlC 300 Mercedes car has a full tank of gas but fuel gauge and range is empty. Theres no check engine light . The fuel does light up when I start the vehicle but went back to off Any help would be appreciated! I think someone had this issue before but I cannot find back the post on how to solve it I drink no issue but I have being using mental fuel gauge as I really don’t know what’s the issue
Old Jun 30, 2025 | 04:51 AM
Mattml430's Avatar
2014 ML63, 2018 GLC43, 1929 DB victory six sports roadster
Scan the car and see if you can get any live data from the fuel sender.
Old Jun 30, 2025 | 06:44 AM
KingWeston's Avatar
Scanner
What’s the best scanner should I get for it?
I bring it to a car mechanic and he said he use the computer scanner and show me a list of possible caus
es
Old Jun 30, 2025 | 03:12 PM
Mattml430's Avatar
Autel are good scanners, get one that suits your budget. It could be something as simple as a plug or wire broken or disconnected. Your mechanic has just given you a list of parts they can throw at it.
Did this happen after re fueling or something else.
Old Jun 30, 2025 | 03:18 PM
KingWeston's Avatar
It happen on a rainy day when I was driving home looking at the gas tank to determine the amount of gas was in the tank I stop the car turn it off and turn it on back the lights come on, on the fuel gauge then went back off and from ever since I have that issue when I start it the car gauge light come on and then when to show the amount in the tank it goes off with no light even when I put full tank with the tank running over
Old Jun 30, 2025 | 03:21 PM
Mattml430's Avatar
Have you checked your fuses
Old Jun 30, 2025 | 03:28 PM
KingWeston's Avatar
I check some fuses not sure if I check the right fuses that related to the fuel gauge because am not sure which fuses operate the fuel gauge I use my multimeter by taking out some of the fuses and test if it makes a beep sound on the meter that’s all and once I hear the beep sound I put it back assume it’s good so am not sure which fuses operate I see a electrical drawing with fuses and location in the back of a fuse box I look through by name If I see anything about fuel gauge or fuel sensor just seeing like odermeter doors lights etc
Old Jun 30, 2025 | 04:16 PM
Mattml430's Avatar
You should have 3 fuse boxes, of google
  1. Cockpit Fuse Box: This is the primary location for most electrical system fuses.
    • It's found on the driver's side, within the cockpit area.
    • You'll need to remove a cover to access the fuses.
  2. Engine Bay Fuse Box: A secondary fuse box is located in the engine bay, near the 12-volt battery.
    • It may require pushing tabs to open
  3. Trunk Fuse Box: There's also a fuse box located in the trunk compartment.
Old Jun 30, 2025 | 04:20 PM
KingWeston's Avatar
I check the fuse box in the truck the one beside the battery and the one at the driver side beside the steering wheel but I will test them again once more to make sure. Cause I remember few days before the incident of the gauge I did use my car to jump start a next car because his car battery died so am wondering if it could impact the fuses after
Old Jun 30, 2025 | 04:26 PM
Mattml430's Avatar
Here is the list of fuses.
https://fuse-box.info/mercedes-benz/...uses-and-relay
You might try pulling the fuel gauge fuse or disconnecting the battery and see if that resets it. Best not to jump start cars due to all the electronics in these cars, unless you have the correct jumper leads or better still a jump start pack.
Old Jun 30, 2025 | 04:31 PM
mikapen's Avatar
You can test all of the fuses while they're in the fuse box by touching the open spots that are visible "in situ" with the probes. The blades that insert into the fuse box are directly connected to the little open metal spots on the surface of the fuse that's visible while the fuse is still inserted.
All you're doing is checking continuity from one side of the fuse to the other.
Old Jun 30, 2025 | 04:32 PM
KingWeston's Avatar
Ok great I will look at the diagram to see which specific fuse is for the fuel gauge instead of going through all of them and I won’t jump start again I did a big mistake
Old Jun 30, 2025 | 04:35 PM
KingWeston's Avatar
Originally Posted by mikapen
You can test all of the fuses while they're pouring the fuse box touching the open spots that are visible "in situ" with the probes.
I don’t really understand what you explain here is it possible to explain in simpler terms are you saying I should keep the car on and test the fuses that s for the fuel gauge
Old Jun 30, 2025 | 04:50 PM
Mattml430's Avatar
He means like this. Car off!
Old Jun 30, 2025 | 04:58 PM
KingWeston's Avatar
oh ok I see I will try that again before I took them out one by one but I will do it this way and see if they all work that means possible issue with the fuel sensor in the tank I am assuming
Old Jun 30, 2025 | 08:25 PM
mikapen's Avatar
Thanks. I couldn't find a good picture.
That way you can test all the fuses in short order.
Old Jun 30, 2025 | 08:28 PM
KingWeston's Avatar
I check all of them not too long ago and they all make connectivity sound on the meter but I will go at it again to make sure I left none untested I just do a ran through but tomorrow I will go at again for sure thanks
Old Jul 1, 2025 | 06:45 PM
UltraSpeed's Avatar
GLS450 S550
Good luck
Old Jul 1, 2025 | 06:47 PM
KingWeston's Avatar
Originally Posted by UltraSpeed
Good luck
I check all fuses and all work so fuses are good
Old Jul 4, 2025 | 11:13 AM
talkr21's Avatar
2017 C63
So this happened to my 2017 glc as well. The dealer replaced the fuel pump. That fixed it
Old Jul 5, 2025 | 11:45 PM
KingWeston's Avatar
oooh so basically it’s the pump because I went to a mechanic yesterday to do a diagnostic he told me there’s no readings from both the sensor so he is saying basically seams it’s the pump or the pump cover needs to change so I guess am going to have to get a new pump
Old Jul 5, 2025 | 11:46 PM
KingWeston's Avatar
I pull the tank myself to inspect the pump it’s showing a bit of corrosion so am going to get a new one and install it thanks
Old Jul 6, 2025 | 01:55 PM
sn202020's Avatar
2017 & 2022 GLC 300 4Matic
If you can start the engine, your fuel pump is working fine. If you're fuel gauge looks bad, then fuel sender issue.
Fuel sender is like a toilet float and sends the different resistance to ECU by the float angle. The plate resisters or the copper contacts worn out then wrong resistance to the ECU, and wrong fuel display happens.
If you can buy only the fuel sender, it's cheaper.
Don't just buy only the small pump itself without the housing which doesn't include new sender.
Old Jul 6, 2025 | 06:19 PM
KingWeston's Avatar
ooh ok I see
I pull it myself took out the pump which I tested it not sure if am doing the right testing way so I bring it to the mechanic he put a scanner on the car he saying there’s no readings coming from both sending unit which he may be thinking it could possibly be the pump cap that the fuel the both fuel sending unit plug into I don’t know
