Its hard to make a recommendation since we dont know where you looked. Make sure to use a flashlight, sometimes its best in the dark, to look for a reflection. My best guess would be between the seat and the center console down near under the seat rail. Just be methodical. Raise seat completely, scanning left to right in one direction and then reverse in the other. Also make sure to think about if you checked your engine or anything in the trunk. Or if the keys bounced all the way across into a map pocket. Just scan everywhere even though you may not think it possible. And, use other senses like running your fingers under in and around everything. Been there done that. Yesterday after a two hour drive I got out and turned off the engine before making sure I had the key, fortunately I did, cause thats another thing that can happen. Leaving cars running, unlocked, locked with key in, all things to learn when we use keyless.
