Things to avoid when washing engine bay
Old Aug 26, 2025 | 04:41 AM
dadalook's Avatar
Hello,
2020MY here. Going to get the car detailed soon. One of the service included is washing engine bay. They didn't mention whether it is power wash or hand wash with hose and brush. Is it save to do so either way? It sounds not ideal with all those electrical components getting wet potentially firing them.. should I skip or go for it?
Old Aug 26, 2025 | 09:15 PM
DanD.'s Avatar
2018 GLC 4MATIC
I've been doing it this way for many years:
1. Cover the alternator with a plastic bag.
2. Spray on degreaser (I really like the yellow one from Harbor Freight).
3. Let it sit for a few minutes.
4. Rinse with pressure washer using at least a 40-degree nozzle, from a distance of 1-2 meters -- never up close.
5. Repeat a few times as needed.
No brushes required. I usually do this every two years, and everything comes out clean with no electrical issues.
Old Aug 26, 2025 | 10:16 PM
W205C43PFL's Avatar
Originally Posted by dadalook
Hello,
Good advice but genuine question, is it safer to not use any water instead? Are there some products that can act as water but won't damage electricals? I thought about using deionized water but of course the chances of it being ionized is high.
Old Aug 27, 2025 | 02:37 PM
Mike0Ryan's Avatar
2019 GLC 300
I understand why you might think that deionized (i.e. H2O with impurities removed) water might be preferred because it does not (readily) conduct electricity, however I have to think that the water would become contaminated (and ionizable) as soon at it came into contact with the grime that you are trying to wash off.
Old Aug 27, 2025 | 06:31 PM
W205C43PFL's Avatar
Mhmm, that was what I thought.
Old Aug 28, 2025 | 09:45 PM
sn202020's Avatar
2017 & 2022 GLC 300 4Matic
Well.. because my vehicle is not classic model car for showing under the hood at a festival,
no one look at my engine bay except myself or rarely mechanic.
I used to clean it twice with a degreaser spray and water, decades ago, but not anymore since, No benefit.
Only if the dirty spot needs to be cleaned for future diagnosis, like oil leak,
I use paper/cloth towel with alcohol spray or break cleaner. That's all.
Old Aug 29, 2025 | 12:05 PM
mikapen's Avatar
I think that a clean engine bay makes a technician respect your car more. Maybe it inspires them to do a better job.
Maybe the inverse is more accurate, though - a dirty engine compartment shows that you don't care.
My engine bay is pretty tidy, with only dust and a bit of road spatter. It only takes a hose to make it look nice.
Old Aug 29, 2025 | 12:32 PM
dadalook's Avatar
Thanks all for the reply. I asked the detailer after the job and they said they power wash.. Glad I asked here beforehand.
Old Aug 29, 2025 | 10:11 PM
W205C43PFL's Avatar
I am guessing those who live in sandy areas, it is probably not good to have that accumulated in the engine bay either, um.. harmful such as sand blasting?
