Loud "clunk" sound from rear axle area
Subscribe
Nov 8, 2025 | 02:01 PM
My 2023 GLC 300 4matic occasionally makes a loud clunk sound after starting and shifting into reverse. It sounds like an emergency brake or the mild hybrid is locked and released after shifting into park. Universal question: Is anyone experiencing this too, or have you had it identified and fixed? Thanks.
Reply 0
Nov 9, 2025 | 10:58 AM
moved to X253 forum...
Reply 0
Nov 9, 2025 | 12:23 PM
Quote: My 2023 GLC 300 4matic occasionally makes a loud clunk sound after starting and shifting into reverse. It sounds like an emergency brake or the mild hybrid is locked and released after shifting into park. Universal question: Is anyone experiencing this too, or have you had it identified and fixed? Thanks.
Probably the most-reported sound is the parking brake stuck to the disc, because of rust following a carwash or other dousing.
The parking brake is automatically applied at shutdown, but if you release it before opening the door (or some other sequence - I'd have to go out and cogitate) you can avoid the rusting. It's not harmful if that's what you're experiencing.
Reply 1
Nov 10, 2025 | 10:52 PM
I had a very similar experience and it turned out to be the transmission. Diagnosed as a problem with the valve body.
Reply 0
Subscribe
Currently Active Users (1)
