GLC Class (X254) Produced 2023+
Different Tire Sizes?
Old Aug 3, 2023 | 06:41 AM
KJWLI's Avatar
2023 GLC300 4Matic SUV
Full Discloser: I am not a car person!
I have a new 2023 GLC 300 4Matic SUV. I just noticed that it has 235/55 R19 tires on the front and 235/50 R19 tires in the rear. Is it normal to have different size tires front and rear?
Old Aug 3, 2023 | 07:17 AM
HotRodW's Avatar
2021 GLE450
Doesn't sound right. Different size tires are normal when the wheels are different widths (i.e. staggered setup), but I've never seen front and rear tires with the same width but different aspect ratios. Essentially your front tires have slightly more sidewall than the rear tires, and that shouldn't be. Check the tag inside the drivers door for the OE tire specs. I suspect it will show both front and rear tires should be size 235/55/R19.
Old Aug 3, 2023 | 07:30 AM
KJWLI's Avatar
It does seem wrong to me. I’ll check the door and have already reached out to the dealer.
Old Aug 3, 2023 | 08:26 AM
KJWLI's Avatar
UPDATE: I was wrong. Tires are actually 235/55 R19 Front & 255/50 R119 Rear Thanks everyone 🤪
Old Nov 28, 2023 | 06:20 PM
DXU995's Avatar
GLC300 4MATIC
Actually, I have the same situation. The difference is to consider the stability and safety.
I am not sure the real reason.
Old Nov 30, 2023 | 12:06 AM
6G Schnell's Avatar
2021 E63S and 2025 GT63
19 inch AMG wheels are staggered. 235/55 R19 tires on the front and 255/50 R19 tires in the rear.
From MBUSA:
“The staggered-width 19-inch AMG® alloy wheels are fitted with all-season tires.”
Hope this helps.
Old Dec 2, 2023 | 12:48 PM
RamC's Avatar
GLC300
Hi,
I bought my GLC in June this year. However, all my tires are of the same size 235/60 R18. I read on the internet that usually all tires are of the same size, however, if they are different, then they can be different for front and rear axles (that too if the manufacturer recommends), not on the same axle. I suggest you check with the dealer.
Regards,
Ram
Old Dec 7, 2023 | 12:20 AM
nk31's Avatar
2023 GLC 300 4MATIC
In Canada, with the AMG package you get Staggered setup with 235/55R19 front and 255/50R19 rear.
Old Dec 7, 2023 | 01:01 AM
6G Schnell's Avatar
19 inch AMG wheels are staggered as MBUSA SITE IS SHOWING
18 inch base model are not
its all published there, don’t understand what is confusion about staggered wheels?
Old Dec 7, 2023 | 09:48 AM
Gitzer's Avatar
2023 GLC 300, 2021 VW ID4
Just want to ask, are the photos in your profile current? I ask because the car shown is not a 2023 (X254), it appears to be an earlier year (X253).
