Wife wants GLC43 but I知 now worried
"Battery discharged" happened to me again, will bring it to service in May.
It feels like the X254 was rushed out... Not sure why it has so many prominent problems which I thought they would have caught it during testing.
Some of the common problems I observed reading here and also in the GLC 300 group on facebook.
1) battery discharged within a day.
2) The car refused to go onto 'D', and it usually comes with a stack of inoperative messages.
3) Active emergency unavailable / active emergency inoperative while driving
4) The GLC suddenly tighten the seat belt as though you are already gonna have an accident.
For #1 - Good news is it can be fixed by a software update for the 4 door handles. For odd reason it is constantly searching for the key which keeps the central computer awake.
#2 - 48v battery problem? I heard there is now a software update solution
#3 - fuse problem? mine had a new steerling wheel, main control unit and software update. Still didn't fix it. Kind of given up, car is going back in later this month.
#4 - not sure.
#4 - not sure.
Fingers crossed for MY25!
You're not referring to when the car gives you a "hug" when first applying the seat belt, are you? This is normal for Mercedes.
Not the initial drive-off hug. It was my wife who experienced it, so I can't give details on how it is like. It happened while driving when she was coming to a stop at the lights. My wifey has lost confidence in the GLC...
EWL5 (04-15-2024)
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
#32
#4 - not sure.
#4 - not sure.
But in my case only 1 small one. Replaced the parking light module. The 12 volt warning comes occasionally but that痴 happened with my 2020 and is caused for the most part by having an accessory on without having the vehicle running.
#33
There will be a lot of happy customers not posting anything, what we see on the forum are usually the unhappy ones. But then this car is so new that I don't even see them as often on the road and there are already so many complains... So my guess is quite a high ratio. 48v and battery drain problems seem to hit a plague
#34
@haitham.said, is there a conclusion to your saga?
coldblood (05-15-2024)
#36
#37
Well we ended up purchasing the GLC 43 on March 27th and by the 29th it was inoperable...
Even on the first day after bringing the car home and then going for dinner later that evening I noticed some issues with the transmission. Taking off from a stop light required a lot of throttle and the transmission would be rough. Going up inclines at slow speed the transmission seemed to be confused about which gear to shift into (driven in comfort mode). And then when reversing the car did not want to reverse slowly and would buck and judder. I tried not to think about it too much and put it down to maybe not being used to the throttle sensitivity driving a new car but I knew it was wrong - my other cars are a GT3 and F8 so I feel I have experience with sensitive throttles. The next day I drove the car and I didn't experience as many issues but still noticed a jerky reverse gear.
Then on Friday the 29th my wife took her mom out to shop and after a few hours when they wanted to leave the car would not start and kept flashing a "Fob not Found" error. She could unlock and lock the car and turn on the display and play music and charge her phone but the car just refused to start, even after placing the key in the designated area in the console. I thought maybe it was just the key so I left work early and brought the second key but still no dice. Tried everything for an hour and couldn't get it to crank. To make matters worse the car was parked in an underground garage so not easy to tow out.
Thankfully the dealer sent a GLE350 as a loaner so I could go home and it drives MUCH smoother. None of the transmission issues I noticed in the GLC. I still don't know what is wrong with the GLC and not even sure if they were able to get the car out of the garage (tried to forget about it over Easter) but the experience after two days has been BAD.
works out for you and your wife.
#38
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,970 Likes
2017 GLE350 4MATIC
MB transmissions have been poor since at least the 7G.
#39
I too have noticed a significant hesitation in the transmission especially from a dead stop since day 1. I have a little over 1000 miles on it now. Coming from a BMW X4 M40i, it was extremely noticeable. I am getting a little used to it. I can see where it can be dangerous when trying to merge on street from a dead stop. It feels like the car doesn't respond for a second or two. Not to mention the ANNOYING rattle from the center console behind the navigation screen. Finally got rid of it by shoving some pieces of rubber behind the nav screen. It's a shame this is the case in a $75k vehicle.
#40
#41
No sir. It's definitely not the start/stop. I've had numerous cars with start stop and I know what that feels like. This is when the engine is running after it start. I have to depress the gas pedal 1/4th of an inch for the transmission to respond. It kind of jerks and lurches forward.
#42
#43
#45
@haitham.said, has the fix largely been favorable? The GLC could probably use some positive news!
#46
Generally yes but I got a call from her today that after she started the car and was talking to her mom on the bluetooth there was a very loud beep and all the screens went black. So now I have to figure out what that was all about.
~400 miles on the clock. Beginning to think the GLC is just garbage.
#47
#48
A faraday bag is going a bit far but I honestly think Mercedes expected nearly all owners of their luxury branded cars to keep their cars locked and keys far enough away (shocker, I know!).
I think Mercedes is fighting a 48V uphill battle if they think they can force every American to think like they do!
