GLC Class (X254) Produced 2023+
Hidden Menu
Old Jun 22, 2024 | 03:05 PM
6G Schnell's Avatar
2021 E63S and 2025 GT63
Thumbs up Hidden Menu
For members interested in reading battery voltages and other data about the car, please see samples below.
Hint: with the power ON, on the left side of the steering wheel press HOME and hold for 10 sec, then pres and hold OK for 10 sec, Then OK for 1 sec…
Enjoy!
Last edited by 6G Schnell; Jun 22, 2024 at 03:07 PM. Reason: Missed important step
Old Jun 22, 2024 | 06:06 PM
W205C43PFL's Avatar
Enjoy!
Is that the same menu as where you reset the oil, ASSYST PLUS?
Old Jun 22, 2024 | 06:18 PM
6G Schnell's Avatar
Did not go into submenus and don’t know if this enables resetting oil change/service intervals and such…
Old Jun 22, 2024 | 07:36 PM
W205C43PFL's Avatar
I see, reason I asked was because that menu was exactly the same as back in COMAND days or MBUX 1.0 where you can view battery voltage, vehicle data, VIN, chassis code, build number etc. and it is where you reset the service interval (under the menu ASSYST PLUS) other than using XENTRY or a capable scanner.
Old Jun 22, 2024 | 08:38 PM
6G Schnell's Avatar
Thanks for the info. Will walk through the submenus to see what is available. My service A is not due till November, so nothing pressing at this time.
Reading battery voltages is great as I cannot hook up voltmeter to the 46 v battery….
Old Jun 23, 2024 | 07:12 AM
W205C43PFL's Avatar
You're very welcome and sounds good.
Old Jun 23, 2024 | 09:29 AM
DESAL's Avatar
GLC SUV 350e Verde Silver Metallic
Enjoy!
Help. Can’t get in. Tried with car running and just power on. Got the following. Said No for shortcut. Not sure what system suspended means. Won’t go away Any ideas. Really would like to get it to work.
uts
Old Jun 23, 2024 | 09:38 AM
W205C43PFL's Avatar
https://cimg2.ibsrv.net/gimg/www.mbw...37163204b.jpeg
https://cimg0.ibsrv.net/gimg/www.mbw...7ac36c3dc.jpeg
uts
Try first heading to the trip menu... it has be showing the odometer and the last trip. This is true for COMAND and MBUX 1.0 days but I am not sure if still the same for MBUX 2.0.
Old Jun 23, 2024 | 09:42 AM
W205C43PFL's Avatar
As for system suspended it simply means engine is not on and you are not actively driving, so attention assist is not functioning.
Edit: That thing is basically the system that calculates the time you had been driving without stopping and the steering movements/corrections before it suggests you to take a (coffee) break.
Old Jun 23, 2024 | 08:24 PM
W205C43PFL's Avatar
uts
https://mbworld.org/forums/w213-amg/...ml#post8990737
