GLC Class (X254) Produced 2023+
CarPlay Map between gauges and radio presets
Old Oct 6, 2024 | 09:32 AM
spyked's Avatar
2026 GLC300 4Matic (X254)
Question CarPlay Map between gauges and radio presets
Hello. On GLCs not equipped with the $675 factory nav, will the Apple CarPlay map show up between the speedo and tach in the gauge cluster? I looked at a car with factory nav, and I could cycle through things between the gauges like music, trip/MPG details, and the map. I didn't try it in a car with no factory nav using only CarPlay.
Does CarPlay map show up there, or will it only be on the HVAC screen? Thank you.
Also, I couldn't find a traditional radio "pre-set" area. Is that now "Favorites"? If so, can you cycle through those radio station favorites using steering wheel controls? Thanks!
Old Oct 6, 2024 | 06:14 PM
superswiss's Avatar
2019 C63CS
No, it won't show up in the instrument cluster. CarPlay has the ability to drive an auxiliary display. It can technically show turn-by-turn directions in the instrument cluster, but I believe MB still hasn't added support for it.
Old Oct 6, 2024 | 08:17 PM
spyked's Avatar
Thanks for the reply. I understand the "factory" NAV might be able to be added/purchased on those cars that don't have it already. Might consider that.
Old Oct 7, 2024 | 11:30 AM
JimFE's Avatar
2022 A220 4Matic
FWIW, on my A220 (not the GLC) which doesn't have MB nav, I do get turn by turn directions between the dials when running Google Maps under Android Auto. No map, though.
Old Oct 7, 2024 | 12:41 PM
superswiss's Avatar
2019 C63CS
Yes, MB has implemented this for Android Auto, but not CarPlay as far as I know.
Old Oct 7, 2024 | 05:19 PM
DESAL's Avatar
GLC SUV 350e4 Verde Silver Metallic
Over the summer I visited with my daughter. The day after I landed she picked up a 2024 Audi Q2 without Nav. We put 2800 mikes/4500 kilo using Waze which shows on her car play. She elected Waze over Apple or Google because it announces “cops” & “speed cameras “. (No tickets this yr). In any case all 3 show on the car play screen only but the sound comes from the car’s speakers.
Had no problem following directions although I’m use to my GLC showing maps on my heads up & instrument screen.
