New Owners, questions, round 2
- Is there an audio "Source" cycle button/feature anywhere? I am soooo used to having a Source button or feature on the steering wheel (including older MBs). In this car, the only way I can change audio sources is via the center screen. Is that right, or is there some steering wheel Source function I am missing?
- Regarding Center Screen, my car glitched the other day about 2 minutes after start up. Screen went black-ish, with faint MB star symbols (I think), and it just came back on it's own in about 30 seconds. But CarPlay was gone. I had to stop, unpair my phone completely, re-pair it, then turn off car again, and it worked. Is there a way to Restart the center screen, not "Reset" it? I see how to "Reset", per Center Screen options and Owners Manual, but that is resetting the data, not the screen. Anyway, if the screen isn't working, you can't very well get to the Settings menu. Is there a Restart screen shortcut? I've tried holding what looks like the power button and that does nothing. If I just press it quickly I get options to turn off screen or turn off system. Is there a hard reboot or restart process? When I look online, I only see that option (Star button and Telephone button pressed at same time) on what looks like old Comand center mouse/dials.
- When I am done with a drive, and turn engine off, and lock the car, it makes noises. I am used to that. Engine bay whirring, heat shields popping, etc. But on my car, the rear of the car has what sounds like a pump whirring for a solid 3:30-5 minutes. I've timed it. It ends with a louder 1 second PHEW sound. Not causing any issues that I know of, just curious what is running back there. Near gas tank opening I can really hear it. Only thing back there might be a fuel pump? I know the battery is on that side back there near spare tire, but that shouldn't be needing any pumps of any kind since it's the 12v. Anyone know what service is running? I do not have an air suspension, base U.S. spec here.
2. You could hold the power button or was it the star button for a few seconds to reboot the screen
3. noises as in these ones? https://mbworld.org/forums/glc-class...en-parked.html
That said, did you enable zero layer, maybe that might help make it easier to use? Basically you hold the home icon and select the style/layer you want.
