GLC Class (X254) Produced 2023+
Digital vehicle key on 2025 GLC
Old Apr 10, 2025 | 05:54 PM
AJCinMD's Avatar
GLC 350e
Originally Posted by Eaton
The GLC digital key is listed as "delayed availability" for model year 2025 (as of October 2024). No indication when it will come yet.
Digital Vehicle Key availability is delayed. All cars are equipped with DVK but currently nonfunctional. An OTA update will be available in the coming months to activate this feature.
Do you have an official source for this information? The Digital Extras team via MBUSA Customer Support is adamant that it's not supported on the 2025 GLC 350e. My dealership seems clueless about it. Just trying to cite an official source for the info and perhaps trsck down and availability date.
Old Apr 10, 2025 | 06:10 PM
W205C43PFL's Avatar
If you checked the vehicle data card, does the vehicle have the code 896? You will need that, Pre-installation for digital key smartphone (something along those lines)
Old Apr 10, 2025 | 09:31 PM
Eaton's Avatar
Top Answer: 1
That second line was copied from the latest order guide from 10/16/2024.
Also, this is from a separate FAQ doc:
Old Apr 10, 2025 | 10:04 PM
W205C43PFL's Avatar
Wait didn't know the 2024 EQS SUV have digital key what about sedan, I mean I haven't heard forum members of both models discussing about it on the forums though.
Old Apr 10, 2025 | 10:07 PM
Eaton's Avatar
Top Answer: 1
I think only the Maybach version got it for 2024.
Old Apr 10, 2025 | 10:09 PM
W205C43PFL's Avatar
I see, that explains it.
  #32
Eaton's Avatar
Top Answer: 1
Attached are user guides for the digital key.
Old Apr 10, 2025 | 10:10 PM
  #33
W205C43PFL's Avatar
Yay! Thanks forum member Eaton for posting these.
Old Apr 21, 2025 | 07:55 AM
  #34
Brufast's Avatar
Hi guys.. Got my GLC300 coupe in Brazil and the same thing… 896 listed but without any option to install it, doesn’t appear on app…. I will wait for some OTA update soon.. This feature is vital for me, I had a new X1 msport and I used all the time this feature, my two keys always in the drawer
Old Oct 18, 2025 | 05:33 AM
  #35
Mukul Soni's Avatar
Mercedes Benz GLC
Originally Posted by MickeyZ
Has anyone with 2025 GLC any experience with the digital vehicle key? According to this page https://www.mbusa.com/en/mercedes-benz-app GLC should have it (Available for 2024 and newer EQS Maybach SUV and E-Class Sedan, 2025 GLC, EQE, EQS, and S-Class), but I can't find any settings/option to set it up either through the MBUX, or the iPhone's Mercedes-Benz app.
I hope you have solved this issue by now. I’m from Switzerland, just few weeks back got my new GLC and got the digital vehicle key option in Mercedes Benz app but it always shows “pairing not possible”. Contacted customer support and after few days they asked me to bring it to Mercedes garage. They kept my car for a night and next day it worked fine. They said that it was system configuration fault and they had to reset and reinstall whole system again.
Old Oct 19, 2025 | 01:30 PM
  #36
MickeyZ's Avatar
2025 GLC 350e
Unfortunately it is still not working in the US. The option to setup the digital vehicle key is available in MBUX and starting the setup displays a screen on the iPhone to add the key to the Wallet app, but it asks for an eight digit pairing code. This code apparently should be displayed on the phone, but it isn't. I called MB support and they said the MB engineers were still working on it. They couldn't provide a data when it will be available.
Old Oct 19, 2025 | 02:50 PM
  #37
Mukul Soni's Avatar
Mercedes Benz GLC
Are they saying that the “Digital vehicle key” feature is not supported in the US? It shouldn’t be a location-specific feature. If you’ve paid for this feature, Mercedes should definitely provide the 8-digit code by email. After reconfiguring my car system, I received an email mentioning the configuration steps through the app, through the iPhone wallet, and with the 8-digit code to configure with MBUX. I didn’t receive that email initially when I encountered the “Pairing not possible” error, but after resetting, I received the email immediately. Even without the code, I was able to configure it through the mobile app. I suppose you should have spoken to them directly if you’re paying for this feature.
Old Oct 20, 2025 | 08:03 AM
  #38
DESAL's Avatar
GLC SUV 350e4 Verde Silver Metallic
On my new GLC 350e SUV I had no problem setting it and using it. But I had to uninstall because for some reason its Bluetooth connection interfered with my Bluetooth hearing aids. Wouldn’t allow me to connect to the iPhone. It was the only Bluetooth connection that had a problem. Oh well back to keyless entry.
Old Oct 21, 2025 | 12:43 AM
  #39
MickeyZ's Avatar
2025 GLC 350e
I thought that Digital Vehicle Key uses Ultra Wide Band and NFC, not Bluetooth.
What version of MBUX and mobile app do you have that allowed you to set it up?
Old Oct 21, 2025 | 03:26 AM
  #40
superswiss's Avatar
2019 C63CS
Correct, the Digital Key uses UWB, which has nothing to do with Bluetooth. Operates on completely different frequencies and is an entirely different protocol. But could be a software glitch on the iOS side related to the BT hearing aids. Which iPhone and iOS version did this happen with?
Old Oct 22, 2025 | 06:49 AM
  #41
DESAL's Avatar
Ok guy’s But there is something connecting to Bluetooth and interfering with my particular hearing aids only when I want to use the hearing aid with a phone call. It doesn’t interfere with streaming music!
My MBUX is version E333.7.1-56, Me app is 3.60.0 US using iPhone 15 pro max. Accessory is automatically connected by the software and shows up in my Bluetooth along with the key that is added to my wallet. You can’t “forget “ accessory inside Bluetooth you have to delete from Mercedes me in the setup. Any ideas as to why? Like I said back to keyless entry which works.
4
Old Oct 22, 2025 | 01:03 PM
  #42
DESAL's Avatar
UPDATE - with all the installing, re-installing and resetting for some reason the Digital key is not interfering with the hearing aids. This is good news for the hard of hearing!! Or maybe just me!
Old Oct 23, 2025 | 01:16 AM
  #43
MickeyZ's Avatar
2025 GLC 350e
I have the same Mercedes Me app version and I don't have the Digital Vehicle Key option in the app. MBUX version in my GLC 350e appears to be newer than yours - E333.8-58, MBUX does have an option to start setting up Digital Vehicle Key, but it always fails. The only thing I can think of is that they did not enable something in our vehicle configuration on the Mercedes service side and the Digital Vehicle Key option does not show up in the Mercedes Me app.
Old Oct 23, 2025 | 09:03 AM
  #44
DESAL's Avatar
The 2 photos that say Not Compatible are from my iPad. The Active photo is from my iPhone. Both iPhone & iPad Mercedes Me apps are v3.60.0. I guess we both need a trip to dealer and may get some answers. But chances are they won’t know and point you to another source…
Old Oct 24, 2025 | 12:12 AM
  #45
MickeyZ's Avatar
2025 GLC 350e
I see you have MY26 (254X), I have MY25 254X, so I wonder if what the Mercedes representative told me on the phone is true - they are still working on enabling it on MY25, but MY26 already has it enabled.
Old Nov 18, 2025 | 11:42 PM
  #46
Paul in SJ's Avatar
2026 Mercedes GLC300, 2015 Porsche GT3
This may be old news, but I just purchased a 2026 GLC300, and did indeed get digital key to work, both on my phone and my Apple Watch. It took a while to get it activated, I finally solved it by going to the Mercedes-Benz app, then clicking on the little portrait in the upper left corner, then clicking on the larger portrait at the top of the screen, then scrolling to the bottom and completing the "identity check" item. It prompts you to take a photo of your photo ID and a selfie. A few minutes later the task completes.
Old Nov 18, 2025 | 11:48 PM
  #47
MickeyZ's Avatar
2025 GLC 350e
Did you have "Digital Vehicle Key" under Remote Controls in the Mercedes mobile app before you went through the setup process that included taking a photo of your photo ID and a selfie? I have completed that identity check and I don't have that option. As previously mentioned, I suspect that MY26 models might have it enabled now, but MY25 don't.
Old Nov 18, 2025 | 11:52 PM
  #48
Paul in SJ's Avatar
I believe so, it just mysteriously wouldn't activate until I found the hidden identity check section.
It was in the "MBUX Comfort" category in "Digital Extras"
Old Jan 2, 2026 | 06:04 PM
  #49
DFBDFB's Avatar
I drive the 2025 GLC 300 4Matic, and I am also not able to see the digital key feature. I don't see the little portrait in the upper left corner of the M-B app. Will you share a screenshot?
Old Jan 5, 2026 | 08:25 PM
  #50
Paul in SJ's Avatar
I have disabled the digital key feature on my 2026 GLC because I was experiencing mystery cases of the car alarm going off when I opened a door which was already unlocked. I had noticed that the car would "respond" to me walking near it with my phone in my pocket, making clicking and whirring noises and started wondering if all these encounters might have something to do with the car getting into a confused state where it thought it was locked when it wasn't. So far I haven't had any more "alarming" events, so as time goes on I'll gain more confidence in my theory.
