GLC Class (X254) Produced 2023+
GLC rear camera opening and closing while driving
Old Apr 4, 2026 | 07:49 AM
SashMB's Avatar
Exclamation GLC rear camera opening and closing while driving
I am really pissed off of my rear camera constantly opening and closing while driving at low speed upto ~35 km/h. There is public unofficial information that this is for calibration purposes but noting in the Manual. No image is shown in the MBUX while opened. Not a problem but only if the opening and closing was not that noisy. This happens every time the car starts and reaches constant speed ~18-35km/h and if car is driven straight. If you turn or speed up, camera retracts and tries again when you slow-down.
Anyone has similar bad experience? Defect, bug, or little from both? Any cure?
Old Apr 4, 2026 | 09:50 AM
W205C43PFL's Avatar
No fix as it is normal behaviour for this model and newer MBs, the only thing you could do is add sound insulation material yourself or turn on the music. The former was done by folks with the V167 GLE. See those threads for more information.
Old Apr 5, 2026 | 12:06 PM
CZ.in.GA's Avatar
Veteran: Navy
2025 GLC 350e
Take your car to the dealer and complain about the noise. They’ll install a MB sound insulation kit under warranty.
Old Apr 5, 2026 | 12:44 PM
W205C43PFL's Avatar
Neat, do you mind telling us the part number in case those don't want to deal with arranging time to go to the dealership and just want to DIY? Thanks!
Old Apr 5, 2026 | 01:20 PM
Paul in SJ's Avatar
2026 Mercedes GLC300, 2015 Porsche GT3
Some report that this technique fixes the spurious camera deployment.
Old Apr 5, 2026 | 02:23 PM
Paul in SJ's Avatar
I played around with this a bit (and got some strange looks from the neighbors). Here's how it seems to work on my vehicle:
1) The camera opens when the car is put in gear.
2) The camera closes when you go above 22 MPH
3) The camera opens again every time you slow down below about 15 MPH
*** HOWEVER ***
If you drive below 22 MPH for 15 seconds or so, the camera seems satisfied, and retracts, and will stay retracted until the next time you start the car (or get close to something).
So, if you can manage to stay below 22 MPH for the first 15 seconds or so of your drive, you shouldn't experience the constant noise of deploying of the camera.
I'd be interested if others see the same behavior, or if it's just my car.
Old Apr 5, 2026 | 04:46 PM
CZ.in.GA's Avatar
Veteran: Navy
2025 GLC 350e
I dug out the paperwork I received when I got the car back after they installed the kit, and no part number is listed. It was done under warranty, so no charge. You’ll have to talk to the parts department if you just want to buy the sound deadening kit.
Old Apr 5, 2026 | 05:22 PM
W205C43PFL's Avatar
Thanks for checking.
Old Apr 5, 2026 | 07:07 PM
Paul in SJ's Avatar
Take this for what it is, but ChatGPT says:
"Mercedes-Benz dealerships often address excessive rear camera deployment noise by installing specialized sound-dampening materials, such as
adhesive-backed insulation (often referred to as "Dynamat" style butyl rubber), behind the trunk paneling where the camera mechanism resides.
Common Techniques and Fixes:
  • Adhesive Damping Materials: Technicians apply dense, butyl-rubber-based sheets to the metal panels in the trunk/boot area. This adds mass, reducing the ability of the metal to vibrate and transmit the camera motor's whining or clicking noise into the cabin.
  • Component Replacement: In some cases, dealers may replace the entire rear trunk handle/camera housing unit, although this may not always eliminate the noise if it is designed with high tolerance.
  • Molded Foam: Specific "moulded foam" from Mercedes-Benz is also utilized to absorb the noise.
While dealers often state the noise is "by design" due to the moving mechanism required for the rear view, this sound deadening technique can significantly reduce the volume to an acceptable level. Some owners have reported success using aftermarket, similar adhesive mats (e.g., Kilmat) to mitigate the sound."
Old Apr 6, 2026 | 12:15 PM
ejvette's Avatar
GLC300/GLC300C4
I have had people driving behind me mention that the camera opens and closes frequently while driving slow but can’t say that i can hear it in the cabin
Old Apr 7, 2026 | 08:53 AM
Gitzer's Avatar
2023 GLC 300, 2021 VW ID4
I think all Mercedes have this opening rear camera but some drop down from an overhang and some peak out when the rear emblem flips open. Even my 2016 GLA had it but just for the backup camera. My 2023 GLC does it whenever I slow down to 10 or 20 MPH - very annoying! It does it for several reasons - Parktronic, backup, accident avoidance, I hear it all the time. But for me the noise is secondary, I just wonder with all this opening and closing will it last after the warranty? It would be much better with just a fixed camera with a washer, like my VW that works perfectly. This MB design is much too complex. There are many long threads in multiple MB forums on this subject.
Old Apr 7, 2026 | 05:43 PM
spyked's Avatar
2026 GLC300 4Matic (X254)
Exactly! I don't so much mind the noise, I mind the expense of an after warranty repair on something so needlessly and ridiculously complex.
Old Apr 7, 2026 | 06:05 PM
ejvette's Avatar
GLC300/GLC300C4
i love german cars but i would never own one out of warranty
Old Apr 8, 2026 | 01:54 AM
Paul in SJ's Avatar
This is really true of any modern luxury car. I got hit with an $8k repair right after my warranty ran out on my Acura, even though it had been meticulously maintained.
For another perspective, I just bought a nearly 30 year old German car - I knew I'd have to fix some things, but one has to be prepared for this.
Old Apr 17, 2026 | 09:54 AM
bobtuba's Avatar
W212, X254, VS30
I have this loud obnoxious camera door as well. Car went in on the 1 year / 10k service so I complained about it. Got the car back and they did nothing. "Operating as designed." Not happy.
Old May 9, 2026 | 09:30 AM
EWL5's Avatar
'23 GLS450
I had a 2026 GLC as a loaner for a day and I kept hearing this mechanical sound repeating in the rear. Is this still happening to the latest models?!!!
I observed how quiet the cabin was overall compared to my X3 but this sound ruins the isolation from the outside world and doesn't seem befitting a luxury car.
Old May 9, 2026 | 09:31 AM
W205C43PFL's Avatar
Yes the sound is going to be there. You can't really hear it if it was in a sedan or coupe or cabriolet as loud as the SUV/SUV coupe style, wagons etc.
Old May 9, 2026 | 09:33 AM
W205C43PFL's Avatar
That said, some models (from other brands) like the Macan you constantly hear the exhaust valve opening and closing coming to a stop so that is another sound. (speaking from experience on family member's macan)
Old May 9, 2026 | 09:34 AM
W205C43PFL's Avatar
Here is more on how the calibration works on MBs: https://mbworld.org/forums/c63-c43-a...ml#post9094664
Old May 9, 2026 | 09:39 AM
EWL5's Avatar
'23 GLS450
That's a shame because it probably rules out the 2027 GLC53 that brought back the 6 cylinder!
Old May 9, 2026 | 09:44 AM
W205C43PFL's Avatar
https://cimg5.ibsrv.net/gimg/www.mbw...a3e88f5d62.png
As shown: (Notes: The reversing camera can extend and retract automatically for the purpose of calibration, even though there is no camera image in the display.) https://www.mercedes-benz.com.au/pas...rs-and-cameras
Looks like they also stated it in the operator's manual, that said the fix are
1. install sound insulation oneself
2. turn up the music : )
3. There is also this that at least decrease the sound to be less noiticable https://mbworld.org/forums/gle-class...ml#post9260387
EWL5's Avatar
'23 GLS450
Now I understand why some aggressive pricing for the GLC is happening. Other than the lack of physical controls to fast forward/rewind a podcast I was listening to, I thought the current GLC should have been easy competition for the current X3.
Old May 9, 2026 | 09:49 AM
W205C43PFL's Avatar
MB is getting ready for the GLC EV and has increased production of that model. https://www.drivencarguide.co.nz/new...-bremen-plant/
Old May 9, 2026 | 09:52 AM
EWL5's Avatar
'23 GLS450
Aren't Acuras supposed to be reliable? Also, I would never lump Acura as a "luxury" brand since it clearly has too much of the Honda DNA (more a "premium" brand like Infiniti).
Old May 9, 2026 | 09:56 AM
W205C43PFL's Avatar
With the increased complexity in the vehicles across the industry, even Toyotas haven't been as reliable as before. There is also all this AI stuff that complicate things and the integration of thereof in infotainment.
Speaking of premium brands, Volvo is worth mentioning and other than top notch safety, they don't have the best reliability ratings but safety is number 1, no?
You have already rated this thread Rating: Thread Rating: 1 votes, 2.00 average.
