GLC63 with 1400 miles... check engine light
Old Oct 30, 2018 | 01:55 PM
bsmall1623's Avatar
Current: 2018 GLC63 Retired: 2015 S550, 2012 cls550
Took it in and they said some cylinders are misfiring... taking it apart now. Here we go...
Old Oct 30, 2018 | 03:51 PM
bsmall1623's Avatar
Advisor called, said the technician and floor sup didnt like the way some of the spark plugs looked and they are going to over night a new set. I'll keep everyone updated if that ends up solving the problem or not.
Old Oct 31, 2018 | 11:51 AM
KumaGLC63's Avatar
18'GLC63
Is this the S or the non-S version? I heard a lot off misfire problems on the e63S forum and I don't think they have a solution for it?
Old Oct 31, 2018 | 11:55 AM
bsmall1623's Avatar
This is a 2018 GLC63 SUV (Non S) Still no word from dealer but hopefully they will have an update by end of the day. They did give me a GLE loaner which is quite an upgrade from the Smart Car I was given last time for my S class. :/
Old Oct 31, 2018 | 12:35 PM
KumaGLC63's Avatar
18'GLC63
I'm on 1200 miles and so far so good for me :knockonwood:... Good luck and keep us updated.
Old Oct 31, 2018 | 02:22 PM
bsmall1623's Avatar
So, to clarify, my advisor originally said it was 2 cylinders misfiring, came to be that it was 1 but multiple times. He also said they were swapping out all of the spark plugs, but only ended up doing cylinder 1. We'll see if it ever pops up again. I looked over at the C63 forum and seems like a lot of lemons over there dealing with this issue.
Old May 1, 2019 | 06:51 AM
AMG-ED's Avatar
AMG GLC63
My check engine light cam on last night also. 2018 GLC63 5700 miles. Any update on your post?
Old May 1, 2019 | 02:23 PM
Toughen's Avatar
C63s
My previous c63s have same misfire check engine light when new. But after dealer clear the code it never came back. And the car drive well. Btw I had it for over 60000km.
Old May 2, 2019 | 08:05 AM
petdarrow's Avatar
Golf R
Only 366 miles and I got the check engine light too went away after 20 minutes of driving, hoping it won't come back.
Old May 11, 2019 | 04:59 PM
p31c63amg's Avatar
12-P31 C63 Coupe- 19-GLC 63 S COUPE -18-911 TURBO S 19 AMG GTR COUPE
GLC 63 AMG COUPE
This happens when the values for the oil/trans are not up to temp. The cause getting into the throttle hard. Have a reset done you should be fine
Old May 11, 2019 | 05:03 PM
p31c63amg's Avatar
GLC 63 AMG COUPE
This happens when the values for oil/trans temp are not up to operating temp. the main cause is getting into the throttle to hard, get a re set and you should be fine. Done this one before.
Old Sep 17, 2019 | 01:30 PM
imomoh's Avatar
2015 C 300
what do you mean by what reset, like what kind of reset
Old Sep 17, 2019 | 03:24 PM
tedboss1's Avatar
GLC63 AMG S Coupe
Here is a thread on the same topic:
https://mbworld.org/forums/glc43-glc...miles-cel.html
Old Sep 17, 2019 | 06:52 PM
JW001's Avatar
G63
I was getting CEL after hard pulls on occasion which usually goes away after about 4-5 ignition cycles. Turned out that the small little coolant reservoir was a little low on coolant and triggered a CEL when I was driving it hard. Filled it up and haven't had any issues ever since. I usually top off that reservoir every month or so depending on how much I drive.
Old Sep 18, 2019 | 01:20 AM
p31c63amg's Avatar
What’s crazy is all the sensors are razor sharp. Just had a rear diff issue. I was like two drops shy on diff fluid. This shut down my S Coupe. I had to shut it off and re start. The problem went away. Went to see my AMG tech the reason was seriously like two drops low. All the new technology. This AMG keeps a good eye on its self.
Old Sep 18, 2019 | 01:24 AM
p31c63amg's Avatar
Re set.
The re set is to clear the code in the ecu. All faults will be stored till re-set.
Old Jun 14, 2020 | 01:55 PM
borisW211's Avatar
2007 E350
20' GLC63 check engine light came on at 3,500 miles
I had a check engline light come on for the first time at little over 3,500 miles..no unusual noises or uneven idling...we'll see what the mb service tells me..
Old Jun 14, 2020 | 09:43 PM
JW001's Avatar
G63
Was this after a hard pull? There's a small brake reservoir in the front center of the air intake that get's a little bit low from time to time. On hard acceleration, you may get an CEL. It will go away after 3-4 restarts. You just need to fill it up to prevent that from happening if that's the cause of your CEL.
Old Jun 15, 2020 | 02:19 PM
tedboss1's Avatar
GLC63 AMG S Coupe
There are other threads about the CEL problems.
Old Dec 4, 2021 | 05:01 PM
JM_MB's Avatar
2021 GLC 43
Hi All - I just brought my new GLC 43 into the dealership...was driving on highway and check engine light came on and car would not go above 2000-2500 RPM...I was simply just driving along...car has 1840 miles on it...hopefully they can figure this one out. Before you say anything, YES I followed proper break-in steps...I have only taken it above 4500 to about 5000 rpm twice and both of those times were AFTER 1500 miles...any thoughts?
