Why is my Glc43 lowbeam headlamp always on?
Subscribe
Feb 24, 2018 | 06:39 PM
Hi all,
After i got my car, i noticed the lowbeam lights are always on when I’m driving despite the light control is turned to auto and during daytime. I see other Mercedes passing by with the strip led lights only and looking cool asf lol.
Does anyone know what’s wrong with it? or maybe I’m doing something wrong?
Reply 0
Feb 25, 2018 | 07:10 AM
Have you checked the settings for the lights?
Reply 0
Feb 25, 2018 | 10:46 AM
Quote: Have you checked the settings for the lights?
yes i have. There’s no setting for lowbeams.
Reply 0
Feb 25, 2018 | 12:40 PM
Would help if we knew where you are, rules on lighting are country specific.
Reply 0
Feb 25, 2018 | 01:05 PM
Quote: Would help if we knew where you are, rules on lighting are country specific.
I’m in Toronto Canada. But the thing is I see other Mercedes with led strip lights only on the road, mine shouldn’t be different should it?
Reply 0
Feb 25, 2018 | 02:19 PM
You are correct, should be same as others, dealer will be able to advise.
Reply 0
Feb 25, 2018 | 03:28 PM
The light sensor is in the top of the windscreen behind the rear view mirror, you can test it by covering or putting light onto it.
If you're in Toronto at this time of year wouldn't it be dark/gloomy a lot of the time thus the headlights would be frequently on?
Reply 0
Feb 25, 2018 | 03:30 PM
Quote: The light sensor is in the top of the windscreen behind the rear view mirror, you can test it by covering or putting light onto it.
ahh! That’s some useful info, i will try playing with the sensor later. thanks a lot!!
Reply 0
Explore
Feb 28, 2018 | 01:17 PM
Also in Toronto, strip light always on during the day. FYI had my GLC43 in for a noise in the cabin, found out there was a headlight recall. Apparently just an adjustment.
Reply 0
Feb 28, 2018 | 02:32 PM
Quote: Also in Toronto, strip light always on during the day. FYI had my GLC43 in for a noise in the cabin, found out there was a headlight recall. Apparently just an adjustment.
Aren't they meant to be, in UK they are called day time running lights.
Reply 0
Subscribe
Currently Active Users (1)
