Finally Dust-Free Brake Pads for my GLC43
Old Mar 12, 2021 | 10:53 AM
  #51
smoke20's Avatar
2020 GLC63
Originally Posted by lanoipat
Finally got mine too !
I didn't open the boxes yet but did you have to change the brake pad sensor ?
I am going to do the front first since no tools to push the piston back are needed .
I need to understand how the rear needs to be done before taking everything off .
Any good video recommended ?
I got mine at Brakeworld. Mine are for the 63. They included a new sensor for the rear axle...but no new clips. The font pads did not include a sensor and they told me that is just the way it is. Odd. Probably a good idea to install new sensors...but it may very well depend on how much wear you have. I have less than 4,000 and am interested to see what the sensor looks like.
Below is a good reference video for the entire procedure.
This video was most helpful in getting to the correct menu for putting the parking brake into service mode. I gave it a shot and it all worked correctly so I feel good about proceeding with the rears...it did take a few tries, though, to get it right.
Old Mar 12, 2021 | 11:37 AM
  #52
ppodell's Avatar
2014 Acura MDX
sensors
I purchased mine from BrakeWorld. They sold me front and rear sensors for my GLC63. I was told that sensors do not need to be replaced IF you can get them out undamaged which is rare.
https://www.youtube.com/watch?v=cBwUTOW89po&t=520s
https://www.youtube.com/watch?v=YRChwuQo6Qg
sensors
Old Mar 12, 2021 | 04:38 PM
  #53
smoke20's Avatar
2020 GLC63
Just came in from installing the fronts. Having now seen the sensors, fitment, etc...I 100% agree. If it is not broken, just put it back. Mine came out with long nose pliers all good. Went for a ride...got some heat and some hard stops. These are initially very quiet and seem to perform reasonably well. I once replaced Brembos on an SRT8 with a 'clean pad'...can't recall the brand...and there was a difference. Will tackle the rears this weekend.
Old Mar 13, 2021 | 10:18 AM
  #54
smoke20's Avatar
2020 GLC63
Got up early; had donuts and coffee and just finished the rears. Very easy. Just re-used the sensor. If labor to install pads is $300...then this was the best $300 I never spent.
Old May 23, 2021 | 12:11 AM
  #55
eling23's Avatar
soon-to-be 2018 glc43
sensors
How much are sensors? Are they the same for both the 43 and 63? I'll probably just order them if it's not an arm and a leg. Still deciding $106 for the R1 concepts and $300 for the disc italias. Big price difference
Old May 24, 2021 | 12:44 PM
  #56
ParadigmDawg's Avatar
AMG GLC 63s Coupe
I paid like $7 for sensors.
A lot of us have had better luck with the Ceramic pads from RockAuto and they are really inexpensive.
CENTRIC10520470 (105-20470)Brake Pad$ 33.79$ 0.001$ 33.792019 MERCEDES-BENZ GLC63 AMG S 4.0L V8 TurbochargedCENTRIC10512910 (105-12910)Brake Pad$ 66.89$ 0.001$ 66.89ShippingGround$ 9.99Tax $ 8.85Order Total $ 119.52PayPal -$ 119.52Balance Due $ 0.00
Old Aug 8, 2021 | 12:18 AM
  #57
lanoipat's Avatar
2010 Audi S4, 2019 GLC 43,07 BMW Z4 M coupe
Originally Posted by andrew e coupe
I’ve finally gotten my sanity back thanks to www.brakeworld.com with ceramic dust-free pads front & rear.
Disc Italia / Hyper Ceramic (a seamless direct pad swap) - see boxes below for part numbers.
A true 90% reduction in the annoying brake dust.
When you change your Front pad with the Hyper Ceramic did they come with a new metal front plate or you used your old one ?
Mine came without it .
Old Aug 8, 2021 | 06:17 AM
  #58
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
You simply use the existing one. New ones do not come with the pads. Enjoy!
Old Aug 8, 2021 | 11:28 AM
  #59
lanoipat's Avatar
Thanks ! I did the rear yesterday .easy if you have the right tools .
When you did the front ,were you able to change the pads without removing the caliper by pushing the piston back ?
Another ? . I watch many video of front pads replacement on Mercedes and never found one specific to GLC43 . the front pads I received from Italia brake have a metal spring on each of them . Was that what you got ?
I will work on that this afternoon .
Thanks for your help
Old Aug 9, 2021 | 07:03 AM
  #60
Once the pins are out and the old pads are still in place… use a flat screw driver to wedge between the old pad and rotor to retract the piston. This will allow enough room for the new thicker pads to slip in the opening. Reassemble. Enjoy!
Old Aug 9, 2021 | 10:43 AM
  #61
lanoipat's Avatar
Front pads replacement was faster than rear pads .
Thanks .
Old Jun 1, 2022 | 08:05 AM
  #62
ninobrn99's Avatar
Veteran: Navy
'16 GLC 43 AMG
Hmmm...I've been debating on which pads to get for my GLC 43. Thinking I might go ahead with these.
Nino
Old Jun 1, 2022 | 08:43 AM
  #63
Nino
~ You’ll wonder why you waited so long to do so. Amazing reduction in dust.
Old Jun 1, 2022 | 10:00 AM
  #64
Gazwould's Avatar
S204 C250 CDI Sport
Nino
I haven't bought ordinary pads since 1999 !
And so advised my father....
Well since you're in the UK check out these....
Pops is rocking them up front on his Hyundai , bedded all wheels washed and this is the result 1 month later , fronts on the right , what a difference .
Old Jun 2, 2022 | 07:25 AM
  #65
ninobrn99's Avatar
Veteran: Navy
'16 GLC 43 AMG
Working with R1 Concepts to get front and rear cermaic pads and the GEOMET drilled rotors for the rear (along with sensors and hardware). The price of all of those things is just over what a set Disc Italia front pads alone will cost.
Nino
Old May 4, 2023 | 09:20 PM
  #66
TND4LSU's Avatar
AMG GLC 43
ATE ceramics vs disc Italian hyper ceramic….wonder if there would be much difference? Price is a big difference $99 vs $160.
https://www.fcpeuro.com/products/mer...92#description
Old May 4, 2023 | 09:31 PM
  #67
~ stick with the proven pads … Disc Italia
Old Dec 1, 2023 | 12:07 AM
  #68
TND4LSU's Avatar
AMG GLC 43
What do you guys do with your old rotors?
Old Feb 6, 2024 | 09:53 PM
  #69
roncee002's Avatar
GLC 63 AMG
Dust free brake pads
Andrew e coup : did you have to replace the rotors to put these ceramic pads on leave the old rotors on?? I dropped my 2019 GLC 63 off for service and told them I wanted to change to ceramic pads through Mercedes and was told by service tech that I had change rotors, pad and maybe some brackets because they weren't sure if the ceramic pads would fit the same as old pads !! any advice would help !!
Old Feb 7, 2024 | 11:27 AM
  #70
~ no the brake rotors do not need to be changed when adding ceramic pads. now if the rotors are warped or heavily worn... perhaps you could replace them.
dealerships always want to replace rotors when they do brake pads... a big money maker for them.
Old Feb 8, 2024 | 11:38 AM
  #71
lanoipat's Avatar
+1 on that !
I swiped the pads at 30k ,the rotors were fine .
Old Apr 19, 2024 | 04:54 PM
  #72
ninobrn99's Avatar
Veteran: Navy
'16 GLC 43 AMG
Nino
I ended up installing these last month. The brake dust is definitely less, but I feel like the pads have to be warmed up before they fully grab. I purchased mine from BrakeWorld, too.
Old May 2, 2024 | 01:39 PM
  #73
ninobrn99's Avatar
Veteran: Navy
'16 GLC 43 AMG
I’ve had the pads on for a while now. They still need to heat up before they stop well. I probably wouldn’t get them again when it’s time for a replacement. Especially not for the price. I had an incident where a car pulled out in front of me as I was leaving first thing in the morning so the pads were cold. I stopped in time, but it didn’t feel like I was going to.
Old Jun 12, 2024 | 10:37 PM
  #74
eodtim's Avatar
2018 GLC 43 AMG
BrakeWorld is a scam - Frauds.
Biggest disappointment to date. Read this forum and took it for fact.
Ordered from BrakeWorld “disc Italia” pads front and rear + brake sensors for each.
What they sent:
3/4 brake sensors
Brake pads missing springs
A cardboard box with zero quality control
Nothing was wrapped inside the shipping box
Front and rear pads were free-standing - no safety measures or packing
What I’ve done:
Called, emailed, texted each of their provided numbers or email addresses. Asked colleagues and family to contact on my behalf.
What happened:
As soon as they knew it was a complaint or my order number - ignored.
They’ve ignored every single avenue for 3 weeks now.
My fair warning:
Read their BBB reviews.
Read their Google reviews.
Avoid their business.
BrakeWorld has a long history of fraudulent advertising and avoidance of customer contact post-payment.
