Spline Lug Nuts stock?
Old Dec 8, 2018 | 08:06 PM
viper3ez's Avatar
GLC63
Please check your GLC63 lug nuts. are they spline style?
if they are, where is your key/socket?
I do not have one.
my lugnut style
Old Dec 8, 2018 | 09:13 PM
Henry Stark's Avatar
GLC63S
You should have lugbolts not nuts. If we are talking stock bolts they are most likely a flower pattern not spline which a regular socket will fit.
Here is a high end Germany socket that Is the flower pattern. (You can find cheaper but probably not the same quality.)
https://www.kctoolco.com/hazet-905sl...edes-benz-1-2/
I also recommend one of these if your going to do work on your car yourself:
http://www.burgertuning.com/mercedes...d_adapter.html
Old Dec 8, 2018 | 09:43 PM
viper3ez's Avatar
GLC63
you are a hero.
i did consider trying regular sockets on but it was 49 degrees outside so i had enough discouragement not to.
i will order both now.
Old Dec 9, 2018 | 08:19 AM
KumaGLC63's Avatar
18'GLC63
You can use the 6 pointer(not the 12pointer) 17mm deep socket to take those out. Or you can buy that special flower socket, but the 17mm 6pointer works well.
