From E63 to GLC63
If you like loud, I can wholeheartedly endorse saving thousands on the cost of a custom exhaust and just replacing the OEM muffler with straights. (Per above, there is no OEM crossover or resonator section at all before the muffler, so it will be completely straight back to the cats.)
I plan on keeping this car!!!!!!!!!!!!!
1. Buy SSR Downpipes.
2. Custom fabricate Vibrant 7830 High Flow Cats onto downpipes.
3. Install.
Out the door with install it is $2500. Paired with the performance exhaust is great. Sounds decent with the valves closed for around town but when you open it up it sounds like a sceaming banshee.
Also the cats added in really make the sound of the car more refined. Takes away that raspy with the decatted downpipes you hear online in videos. Most importantly the gasoline fumes smell is tamed.
Ill try and get some videos for you guys.
Cheers.
1. Won't it cause check engine lights and all other sorts of problems?
2. Will it actually pass inspection? I'm in New York.
I'm waiting on receiving my 2021 GLC63 and after breaking it in properly, I'm going to want to enhance the volume of the sound. I just want it to rumble without having to drive like a lunatic.
I guess what's the least disruptive way to achieve that?
After googling, I'm seeing that a muffler delete can result in the car not running properly due to the fuel injectors and speed of air flow causing all sorts of software issues.
I'm waiting on my brand new GLC63 and was looking at deleting the muffler to here the rumble. I don't care so much about pops and bangs, I just want too hear a loud rumble.
