ModalWorks Intake GLC 63 Review
Old Apr 10, 2020 | 02:53 AM
GLCya63's Avatar
2020 AMG GLC 63
I've had the pleasure of test fitting the ModalWorks intake for the GLC63 this past week. It's currently on preorder on their website and listed for the C63 (https://modal.works/shop/w205-c63-hi...ntake-preorder). Since most engine parts are a direct fit between the C63 and GLC63, I reached out to them to see if the intake would fit the GLC. The intake tubes and filter are a direct fit, but the heat shields will be modified to fit tight against the hood when production is complete. As you'll see in the pics, the tubes are 3D printed for now, but will be carbon fiber as seen on the website on final release.
ModalWorks
First off, the ModalWorks team has been an absolute pleasure to work with. Fast shipping (even during these times), well packaged, and highly responsive through email.
Install
It took me a little less than an hour to install, but that was taking my time with no instructions yet, but will really take no more than 30 minutes. Very similar to the BMS intake install, but it reuses the OEM standoffs as attachments, so no parts to save for later or risk losing in case you want to revert back to stock. They really spent some time making this intake fit just right. Once the final dimensions for the heat shields are worked out, this unit should fit very nicely in the engine bay. The OEM hood scoop tubes are utilized, maximizing the amount of cold air.
First Drive Impressions
On the first dive out, greatly improved throttle response was the first thing I noticed, very snappy, even at low cruising speeds. And yes, the blow-off and turbo spool is much more audible now. I'm not a huge fan of loud blow-off wooshes, but since the OEM hoses remain attached to the tubes, it's louder, but not annoyingly loud. Some may want it a bit louder, but for those that are turned off by it, no need to worry on this unit, i think it's just right. It adds the right sounds to the already fantastic AMG exhaust note.
You'll see on the website they have dyno results of over 50whp. I can't back that exact number from my butt dyno, but the power increase is definitely there, especially from 5K to redline where the M177 really needs it. I'm currently running a Renntech ECU+ tune, and like most stage 1 tunes, they fall flat after 5500 rpm, this intake makes it pull harder now. Haven't had the chance to get any Dragy yet, but when i can I'll definitely report back on this thread.
Overall
I really wanted to stay away from an aftermarket intake as I didn't want to lose the awesome OEM AMG look in the engine bay. There are some strong M177 builds out there using the stock boxes with high flow filters. After the short time I spent with this intake, I don't really care about that anymore, I'd miss the added power and sounds too much. Best of all, the final unit is only going to get better with the carbon tubes and improved heat shield design. I think it's fairly priced against all current intake offerings, not the cheapest, but with what you get it's the best bang for buck, especially if you can grab their pre-order offer.
OEM hood scoop tubes utilized
Old Apr 10, 2020 | 04:12 AM
CPD SLK's Avatar
2009 C63 AMG
Old Apr 10, 2020 | 10:12 AM
Moonpie64's Avatar
2017 RAM Powerwagon, 2020 GLC 63
Welp, i just figured out what i'm spending my stimulus package on....looks very good man.
Old Apr 10, 2020 | 06:02 PM
ParadigmDawg's Avatar
AMG GLC 63s Coupe
How do you drive an AMG and get a stimulus package?
Old Apr 10, 2020 | 06:44 PM
Moonpie64's Avatar
Damn it, you caught me...drug money isn’t taxed.
For real though, dual income and we barely get anything.
Old Apr 10, 2020 | 08:27 PM
KingMonkeyJr's Avatar
GLC 63 AMG, Trackhawk, X3M
50whp lol.. I’d imagine maybe 10-13 with this system at most.
true the m177 dies out up top due to restriction of airflow with the stock airboxes.
the Weistec one has been good to me. Great turbo noise and response is noticeable. The quality is meh... not what you’d expect from them.
for the price this sounds appetizing.
KING
Old Apr 10, 2020 | 09:18 PM
Moonpie64's Avatar
KING
Agreed, I’m skeptical on the power gain as well, but I’ll stick around to see if it does what it claims. If it comes close, I’d pull the trigger.
Old Apr 10, 2020 | 10:34 PM
ModalWorks's Avatar
SPONSOR
W205 C63
Hey all, just wanted to chime in on power gain. Below is a plot showing the relative power differential on a stage 2 C63. You can see the power gain of 50whp is at the high end of the RPM band... it is not an absolute power increase peak to peak. At peaks it is roughly 20-25whp. Our system really allows the motor to breath up top where the stock system become restrictive. You can also check out our initial post in the C63 section here: https://mbworld.org/forums/c63-c63s-...ks-intake.html
We outline dyno numbers and dragy tests showing significant improvements in the 60-130 and quarter mile times.
These images are also listed on our website under the pre-order section here: https://modal.works/shop/w205-c63-hi...ntake-preorder
Please let us know if you have any questions and we are glad to answer.
Old Apr 13, 2020 | 03:04 PM
K507's Avatar
2018 GLC 63 AMG Coupe
Definitely not CARB compliant for where I live
Old Apr 13, 2020 | 03:28 PM
GLCya63's Avatar
2020 AMG GLC 63
I've put a few more miles with this intake. Still have only driven less than 40 miles total given our current situation, but the overall feel has definitely improved. Added power throughout the Rev range. I've mentioned the throttle response previously, but wow what a difference. Comfort mode is so much better now, RPMs climb easily to redline. It's nice to have the added sound from the engine bay too.
Old Apr 18, 2020 | 08:19 PM
GLCya63's Avatar
2020 AMG GLC 63
Carbon tubes are in! Very nice fit and finish. Thanks Modalworks!
Old Oct 9, 2020 | 05:18 PM
ModalWorks's Avatar
SPONSOR
W205 C63
These kits are back in stock. You can stack our turbo blankets with them as well and get $75 off the blanket purchase with promo code HalfOffBlanket.
Old Oct 12, 2020 | 11:36 AM
303GLC's Avatar
2020 AMG GLC 63s
Probably a dumb question, but does the engine cover go back over this setup or does it all stay exposed?
Old Oct 26, 2020 | 01:47 AM
paste's Avatar
you probably should read the post
Old Oct 26, 2020 | 09:38 AM
303GLC's Avatar
2020 AMG GLC 63s
i did.
Old Oct 27, 2020 | 02:49 PM
TheOtherDodge's Avatar
2005 E55 AMG
Is there any documentation of the power increase (dyno) for a BONE STOCK GLC63?
