Painting side steps? (GLC43)
Old Jul 21, 2020 | 05:23 AM
Boltor's Avatar
GLC43
Has anyone seen or heard of painting the GLC43 (or 63 I guess) side steps black (or other colour)? Interested to know how to remove the plastic pieces to allow for painting.
Thanks!
Old Jul 21, 2020 | 07:34 AM
places's Avatar
No more MB:(
There was a thread about painting the running boards on the G Forum, here it is - https://mbworld.org/forums/g-class-w...ng-boards.html
Old Jul 21, 2020 | 07:38 AM
Boltor's Avatar
GLC43
great! Thank you.
just trying to work out whether the small rubber pieces can be taken off easily (and then reattached).
Old Jul 21, 2020 | 03:26 PM
DMWelk's Avatar
2014 E350 & 2017 GLE 400
Originally Posted by Boltor
great! Thank you.
Have to remove the running board to remove the stainless steel insert.
Old Jul 21, 2020 | 05:16 PM
Boltor's Avatar
GLC43
Perfect! Thank you @DMWelk
Old Jul 21, 2020 | 05:50 PM
brad65ford's Avatar
2020GLC63
so want to remove mind and replace with the side piece none running board
Old Jul 21, 2020 | 11:33 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
I removed the running boards off my 2015ML and found some regular rocker panels on Ebay that were off wrecked car. The only issue was the normal 350 rocker panel is textured black plastic and I wanted them the same color of the car ie white. It was a lot of work sanding them but I later found out I could have had them covered in white vinyl . Also worth a try, you find someone who wants to trade, hopefully local. Good Luck
