2020 GLC32 21inch tires pressure recommendation on TPMS
Old Apr 16, 2021 | 01:11 PM
aviator787's Avatar
2024 GLC43
2020 GLC43 21inch tires pressure recommendation on TPMS
Hello all,
i just put back my summers and the TPMS had to be reset because it detected low pressure.I put some air and reset and now indicates 37 all around from computer TPMS.
Is this a recommended value ?
Although a manual gauge says 35 ( off by 2 from TPMS )
Old Apr 16, 2021 | 02:17 PM
ParadigmDawg's Avatar
AMG GLC 63s Coupe
Originally Posted by aviator787
Hello all,
Open the gas filler compartment and it will tell you the PSI for your load.
I run mine at 33 psi for everyday driving and at 25 psi at the track.
Read this thread:
https://mbworld.org/forums/c63-c63s-...gh-speeds.html
Old Apr 16, 2021 | 03:00 PM
aviator787's Avatar
2024 GLC43
Read this thread:
Ok thanks so basically need to lower from what I get displayed on tpms now at 36
Old Apr 24, 2021 | 07:32 PM
aviator787's Avatar
2024 GLC43
How accurate are the readings from the TPMS I see 44 42 39 39 which are way over inflated on a warm day.
Do I need to deflate to 36?
