Accidentally put 89 instead of 91 in 2020 glc63s
Some people said you'll need to unplug the battery after you fill it up with 91 again, to reset the ecu. Is that true?
How worried should I be? Should I constantly fill up every quarter tank with 94 to counteract it?
About 2/5 of the tank is 89, 3/5 is 91.
No need to reset the ECU. It will adapt rather quickly.
Don't worry about it. If the temps in your area are on the cooler side, it is unlikely anything will happen. If it is 100f outside then I wouldn't go looking for a race until you put some good gas in it. When you get to 1/2 tank, fill it up with the best you can find.
Burn it to the ground and collect insurance money....
(It's fine to run on regular, no harm will come to it at all - it has knock sensors - don't add anything to it like the above suggested - just drive it and stay out of the deep boost if you can).
