Mercedes-AMG GLC 63 / S Coupe Facelift w/ Fi EXHAUST Performance System
Fi EXHAUST AMG C253 GLC63 S Coupe Facelift product page:https://bit.ly/3HUWfFF
Frequency Intelligent Exhaust provides the best of both worlds. It’s the perfect exhaust system for those who want to cruise in comfort and experience sports car resonance and Fi EXHAUST signature frequency at a press of a button.
The Fi EXHAUST has been rigorously tested to offer the highest performance and optimal sound frequency. The exhaust is built from high grade stainless steel material and masterfully detailed and finished using TIG welding producing high quality and clean welds.
When valves are closed exhaust gasses are routed through the muffler resulting in a low-profile comfortable drive. When valves are fully open for maximum flow and performance it creates an exotic tone, intense sports car sound with signature Fi EXHAUST frequency.
Fi users can regulate a desired sound volume from quiet comfort to sporty aggressive using an OEM sport button. In sport mode valves are opened, which improves exhaust gas flow, increases sound volume and spices up exhaust note.
Take the personalization further with our Fi Pro App available both App Store and Google Play. Search “Fi EXHAUST Pro” to download and monitor real-time valve status with the help of our intuitive and user-friendly interface. Assign Auto Mode preferences based on RPM/Speed/Turbo Boost. When Auto Mode is activated, the system will intelligently open valves depending on the auto mode method and set data unit, for example, at 3000RPM.
The optional Fi Pro comes with our sporty 2 button style remote control is lightweight, ergonomic and offers an intuitive way to switch between Street and Race sound profiles. The design is smooth and offers a nice grip, and the aluminum alloy ring can be customized in 14 different colors or switched to forged carbon rings with a unique marble-like texture.
The CEL issue could be solved by the Fi Pro Control System after installed the aftersales market exhaust. On an engine, start-up Fi users can turn on the Auto Scan function to scan and delete any CEL connected to the catalytic converter immediately. This effect can be opened on Fi Pro App and is available on chosen car models. Manual debugging can also eliminate the unwanted CEL attached to the catalytic convertor.
AMG C253 GLC63 S Coupe Facelift features:
- Fi EHXAUST valvetronic catback and downpipe.
- 2 downpipe options to regulate exhaust gas flow and sound: Ultra high flow catless and Sport 200 cell downpipes.
- Fi EXHAUST valve modes are compatible with a OEM sport button to regulate the valve modes.
- Manufactured from a high-grade T304 stainless steel.
- Expert TIG welding techniques.
- Weight reduction compared to OEM/Stock exhaust.
- Comfort/Sport exhaust sound profiles.
- Rigorously sound tuned exhaust sound frequency.
- Horsepower increase and low back pressure.
- Guaranteed bolt-on fitment using precision crafted design.
- Compatible with OEM exhaust tip outlets.
- Available for OPF vehicles.
- Compatible with Mercedes-AMG C253 GLC 63 and GLC 63 S models.
- Available also for Mercedes-AMG X253 GLC 63 / S SUV Facelift (2021) model.
Mercedes-AMG C253 GLC63 S Coupe Facelift (2021) fitted with our full catless system.
Fi EHXAUST is compatible with OEM outlets.
If you wouldn’t mind, could you please contact or PM me the pricing for the system for the GLC63s model. Any peripherals such as remotes and or apps are not needed as I wish to merely plug’n’play with the cars innate systems.
Thanks in advance
