AMR Performance Pro Tuning Suite
What is the AMR Performance Pro Tuning Suite?
The AMR Performance Pro Tuning Suite is an all-in-one OBD flashing that will allow end users to flash AMR Performance provided tune(s) and custom tune(s) to their ECU. The user can live monitor, datalog, switch back to stock, read fault codes, and clear faults all from the comfort of their own home!
What are the Pro Tuning Suite features?
- FREE AUTO-UPDATES
- 100% Plug-and-Play functionality
- Read Trouble Codes in all vehicle modules
- Clear Trouble Codes in all vehicle modules
- Reset Learned Adaptations (octane, knock, fuel, etc...)
- Live Data Monitoring (monitor vehicle parameters live)
- Live Data Monitoring Recording (datalogging)
- Flash all available tunes for your vehicle at your leisure
- Custom tuning capabilities for your own tuner of choice
Have your own tuner?
Not to worry! The AMR Performance Pro Tuning Suite is a one stop shop! You can data log your vehicles parameters, save them and email them to your tuner. Your tuner can make the corrections needed, upload the tune to your account and within seconds of uploading it is now available for programming!
What everyone loves to see, screenshots!
Parameter Logging:
Once connected to your vehicle, all you would need to do is select "START LIVE MONITORING". The software will automatically grab the available monitors and, if available, custom monitors that we have designed specifically for your vehicle. To record the live monitor screen, simply select "LOG MONITOR DATA". To stop monitoring any data, simply select "STOP LIVE MONITORING".
STD PIDS OFF:
If you are just interested in monitoring the custom monitors simply select the "STD PIDS OFF" check box.
How to can I see what tune(s) are available for my car?
Simple! You simple click on "GET ECU" to access your vehicles information. This will give you all information on your vehicle and its ECU. Once selected, the available tune(s) will auto-load into your firmware drop-box along with any custom tunes you have available.
Taking orders now. Contact us today!
Since you have already spoken with someone, I would recommend reaching out to Matt. He can assist you.
We would recommend contacting us directly in regards to this.
