Staggered 63 Wheels
Old Apr 15, 2023 | 11:46 PM
JohnnyUte's Avatar
C350 4matic coupe
Staggered 63 Wheels
I know there are several threads on using GLC63 wheels on a GLC43 and that they fit just fine, but I wanted to double check something before I pull the trigger on a set of GLC63 21s. My biggest concern is the diameter difference between the front and rear wheels. On the GLC43 the wheels front/rear are the exact same size while on the GLC63 there is a 0.2" difference (0.7%) between the front and rear diameters. The 4matic in the GLC43 is the Performance 4matic with a fixed 31:69 torque split whereas the GLC63 is the 4matic+ which can shift the power front and rear a little bit. Am I reading into this too much and there'll be no issue with those wheels on my 43? Or is this something to worry about? I hold onto my cars for awhile so I don't want to risk damaging my transfer case over the length of the car. Unfortunately, I haven't found anything that talks about the transfer case or how the power split works on these cars either. Thanks for the help!
Old Apr 18, 2023 | 10:48 AM
I_love_ICE's Avatar
C63
Should be no issue. I have the stock 21's on my 43 vice the 20's.
Old Apr 18, 2023 | 10:55 AM
JohnnyUte's Avatar
C350 4matic coupe
Is that the stock 43 wheels or stock 63 wheels? If the 63 wheels, do you have pics?
