M177 Engine - Stage 1 Tune on 91 - Worth it?
When reviewing the dyno graphs for tuned M177 engines, it looks like the power and torque falls on its face after around 5.5K rpms. In stock form, I can already tell that the engine is running out of breath at the top end. Will this be even more evident with a tune? If so, then is the tune really worth it if it makes this issue even more apparent? Looking at the RENNtech dyno graph attached, it seems to add insignificant power up on top, with most power gains had in the middle of the power band. I don't know if that will make the car feel like a rollercoaster with power only appearing in the midrange of every gear. I'm not interested in doing any additional mods to help the engine breath better. So it's a Stage 1 on 91 or nothing at all for me. Lastly, do I need a CPC tune to feel the stage 1 ECU tune do its job?
I appreciate those with Stage 1 tune to chime in, especially those running 91. I'm one of the lucky ones to get ***** gas here on the West coast.
TIA!
Some of the tuners have sales if you keep your eye out or will give you a good deal if you talk to them. I’ve seen under 3k for both the cpc and ecu tune. My tune uses the wife’s laptop to flash back and forth between different maps and the stock file. You will need a new cpc to flash, tuners will either send you one that they flashed or read your old one through the obd port then have you install the new one and flash it. Intakes are probably the easiest thing to revert to stock if you need to take it in. I think it took about 10 minutes to install with a screwdriver and pliers for the different clamps. Everything else just pops off.
